What's on your workbench today?
Discussion in 'Tele Home Depot' started by guitarbuilder, Nov 26, 2011.
  1. peterg
    peterg Tele-Meister
    Toronto
    Very nice pickguard! The body needs some work, though. :rolleyes:
    Moodivarius likes this.
  2. E-miel
    E-miel Tele-Meister
    Drenthe, Netherlands
    I don't think it looks bad! It looks like it was assembled with care, I like that.
    I'm also thinking about building a winder. May I ask what kind of motor you used? And at which speed it runs?
  3. peterg
    peterg Tele-Meister
    Toronto
    Thanks!
    Here is the motor I bought. It’s 1000 rpm.
    E-miel and Moodivarius like this.
  4. Freeman Keller
    Fifth barn caster is off my work bench
    and in my music room
  5. harpdog
    harpdog Tele-Afflicted Silver Supporter
    near Chicago
    This July day has weather perfect for maintaining my snowblower. New blades, scraper, and oil change.
  6. Jim_in_PA
    Jim_in_PA Friend of Leo's Silver Supporter
    SE PA - Doylestown PA
    Moved my slabs and "gold plated OSB" today from the old shop to the shed in the backyard. (my storage locker couldn't really take any more stuff at this point)
    Oh, and this very important tool finally made the move, too. LOL
    Someday I hope I'll be done moving. Of course, then I'll be building a building, as it were, and have to move again. But it will be a hundred feet instead of 10 miles.
  7. eallen
    eallen Friend of Leo's
    Zpoxy on a couple mahogany & a walnut body. A little twist with top carve and on an f-hole for musicians who appreciate a rest.
    Oh, and the final coats of clear nitro on a mahogany Jr kit a fellow guitar buff put together.
    20210728_195834.jpg 20210728_184454.jpg 20210724_160357.jpg 20210722_211631.jpg 20210722_211554.jpg 20210722_171534.jpg 20210722_171553.jpg
  8. epizootics
    epizootics Tele-Meister
    Lyon, France
    They are! I make mine RW/RP, but RW would be enough to get the humbucking effect. People don't usually bend their G strings very far up on 12-strings. Those have a very distinctive sound with quite a bit of bite, owing to the fact that those pole pieces are so long! Definitely not one of those pickups you can raise right under the strings in the neck position.
    crazydave911 likes this.
  9. Laren
    Laren Tele-Holic
    West Somerset
    Slowly getting there. Headstock needs another round with the wet and dry and buff and polish :) but the back of the neck looks OK. The body has just had a coat with one more to go on before the old wet and dry buff polish stuff. Almost there now :D
  10. E-miel
    E-miel Tele-Meister
    Thank you for getting back to me. I really appreciate it! Let's see what I can come up with :)
  11. PimR
    PimR TDPRI Member
    netherlands
    gr
    this looks unbelievably fantastic...
  12. Slowtwitch
    Slowtwitch Tele-Holic
    South Africa
    A guy at the place where I volunteer asked me to make him a neck. He bought a Mex Fender strat new and wasn't happy with the "thin" Fender strat neck.
    So I as was honored that he asked me to make him something he would like more :)
    A roasted fat maple neck, nitro finished, big wire, his own logo designs
    He wanted properly rounded edges (anther gripe about the Mex neck having "sharp" edges) and a real bone nut (still to be finished)
    IMG_20210731_113424.jpg IMG_20210731_113715.jpg IMG_20210731_113437.jpg IMG_20210731_113512.jpg IMG_20210731_113606.jpg IMG_20210731_113410.jpg
    This led to him choosing the Mahogany Nitro burst body I shaped (I posted here few months back) over his new Fender body as well :D
  13. Laren
    Laren Tele-Holic
    West Somerset
    Just trying out Crimson's wipe on lacquer. As I don't know the best way to use it I blagged it, it seems to be pretty good. I left it for ten mins and went to buff it but it had set up a bit hard. I knocked it back with some 800 W&D, a bit of compound and a polish. Looks about 85%.
    If you know the best way to use it please let me know. Ta.
    eallen, zippofan, mkster and 2 others like this.
  14. crazydave911
    East Tennessee
    And I used to think my V laminated fretboards of three kinds of wood were something. Trust a guy from County Somerset to blow me away lol
    Had Strats always looked like that maybe I'd love them now :)
    Slowtwitch likes this.
  15. GreatDaneRock
    GreatDaneRock Tele-Afflicted
    Central FL
  16. GunsOfBrixton
    GunsOfBrixton Friend of Leo's
    Rochester, NY
    Working on restoring an old Beatles bass. the back of the neck just below the headstock has a small crack. Most likely due to over tightening of the truss rod. Now the question is, what to do about it? Thinking of carefully running an exacto blade (very shallow) along the crack and then wick in some water thin CA. Then use a touch up marker for color and then top coat. I did cut down a 5mm hex key and was able to loosen and tighten the truss rod. Though I didn't want to crank on it too much. What you recommend I do with the crack?
    Thread here:
    https://www.tdpri.com/threads/late-60s-kimberly-beatles-bass-restoration.1077687/
  17. telepraise
    telepraise Tele-Afflicted
    Tampa Bay
    crazydave911 and eallen like this.
  18. eallen
    Yes, as requested. I chamber or thinline route most of my bodies that get a cap anymore even if not getting an f-hole because few like heavy guitars these days. The walnut tele is going to end up 8.5lbs even with a belly cut.
    Eric
  19. Freeman Keller
    Thank you. 6 pounds 3 ounces. The plantella is slightly smaller than a telecaster and it is not chambered
    crazydave911 and GreatDaneRock like this.
  20. Jim_in_PA
    Ben from Crimson recently used that on a project. He did have to go through the whole leveling thing after a number of applications but it looked good when he was don.
    Laren and crazydave911 like this.
