What's on your workbench today?
Discussion in 'Tele Home Depot' started by guitarbuilder, Nov 26, 2011.
  1. trev333
    Coolum Beach,Australia
    flat sanding with my trusty wall stud sanding board.... lengthways, crossways, diagonalways, round and roundways until all the chalk is gone... then a sand with my palm sander and a scrape down. whew.... morning workout...:D
    another Hoop Pine blank I'm working on....
  2. crazydave911
    East Tennessee
    I'm not really sure WHAT hoop pine is but I believe next to desert eucalyptus it's one of the more beautiful woods you guys have down there
    trev333 likes this.
  3. trev333
    [​IMG] Hoop Pine is a really old pine species from Gondwanaland times when dinosaurs walked here.
  4. NightOwl
    NightOwl Tele-Meister
    Somewhere out there...
    Nothing too inspiring today. Got my hands on a bunch of heavy, northern, baseball bat ash. What better use for wood that's too heavy? Thinline Cabronitas! Gonna do the chambered bodies with a swimming pool route and a walnut top. Might even put a little strip of binding around the top. That should make the weight bearable. That wood is HEAVY!!!
    John Nicholas and crazydave911 like this.
  5. Bob J
    Bob J Tele-Meister
    Portland OR
    Modular built in shelf unit for my sons rental in so-cal. Fits where the built-in ironing board once lived. Storage for spices and cooking oils.
    crazydave911 likes this.
  6. AndrewCW
    AndrewCW TDPRI Member
    Lachlan, Tasmania, Australia
    I got a few bits and pieces this week so I did a little on an Esquire build. I had already enlarged the control cavity but the CTS push/pull and no load pots were a bit bigger so had to enlarge it again. Needed to drill bigger holes in the control plate as well and will need to order new knobs as the ones I have are too small. No wiring done yet as I am waiting on a pot for the Eldred circuit. Happy with the finish as I didn’t want gloss or a thick finish. So today I enlarged the cavity and attached the neck to the body.
    Upgraded Pitbull kit, 2 piece Ash body, maple neck, Gotoh tuners, bone nut, Wilkinson compensated brass saddles, CTS pots, 3 way blade switch, Cavalier Bakersfield/Fat Lion pickup. Push/pull volume will be push for Fat Lion & pull for Bakersfield, 3 way will be straight to jack, volume + tone
    (0.033 cap), Eldred (0.0033 cap).
    8D4A1B67-DD72-4A04-98EA-2D90210D2F68.jpeg 806C97E5-D1AB-48D6-872D-762662AFF040.jpeg DDF4864A-37BF-425D-8D52-75030FAFE83C.jpeg
  7. 1stpitch
    1stpitch TDPRI Member
    South Carolina, USA
    Practice drilling ferrule holes.
    John Nicholas, richa, Laren and 2 others like this.
  8. Zepfan
    Horn Lake, MS
    Fender did make a Tele with a Strat body, Tele pickups, Tele neck and Tele pickguard. Girl that lived next door to me had one and a original silver face DR.
    peterg likes this.
  9. Zepfan
    Horn Lake, MS
    Those pickups look exactly like the ones used on the Messenger in it's original form before Mark Farner started modifying it. So I looked at the pickups on the Gutarfetish site and none of them are the same size. The old NY single coil they make is close to the same size, but it may be sealed into that cover.
    Does anyone have any experience with the GFS NY pickup? Is the coil sealed into the cover with epoxy?
  10. Moodivarius
    Moodivarius Tele-Holic Silver Supporter
    Northwest Ontario
    Wood pickup cover 2.0.
    Walnut 2.0, Cherrywood 1.0
    I’ll have to tweak the tool-paths in the CNC software. Not much room to adjust size. Pick guard route has to be a specific size, as well as the inner route to fit the bobbin.
    Good thing I have lots of scraps to play with. :)
    Scott
    Fendereedo, dougstrum and Zepfan like this.
  11. crazydave911
    East Tennessee
    I do actually, about to put it in my Guild knockoff. I actually bought it for my Jazz guitar I call it but WAY to hot. It's actually a P90 in drag and the shell pops right off (though there is no way to mount it otherwise) and is surface mount. I replaced it the Goldfoil which was more what I was looking for in THAT guitar. Mine is the neck version, the bridge is even taller and hotter so you may need two neck versions for clearance. They DID have sound samples but I haven't looked in a long time
    Zepfan likes this.
  12. Zepfan
    Horn Lake, MS
    Thanks. It's the NYII and their take on a Dynasonic right?
  13. crazydave911
    East Tennessee
    Actually a slug P90. Those poles are the slugs instead of screws with the bar magnet each side on the bottom. I'll try to take pics later
    Zepfan likes this.
  14. Jim_in_PA
    Jim_in_PA Friend of Leo's Silver Supporter
    SE PA near New Hope PA
    My big yellow shop assistant was busy yesterday and today...
  15. rstaaf
    rstaaf Tele-Holic Gold Supporter
    Here
    New Micarta scales and Titanium hardware upgrades for the Spyderco Para 3.
  16. Moodivarius
    Northwest Ontario
    Wood pickup cover 6.0. :D
    The walnut cover will match the sound hole when finished with nitro.
    Scott
  17. Ripthorn
    Ripthorn Friend of Leo's
    Austin, TX
  18. epizootics
    epizootics Tele-Meister
    Lyon, France
    Fresh off the workbench...
    25" scale, ash (no pore fill) body, rowan neck with a bubinga fretboard, Gotoh Floyd Rose & no locking nut...the strings are kept in place against the zero fret by an acetal nut to minimize friction. Tuners are Gotoh vintage-style magnum locks. It stays in tune no matter how much I abuse that trem. The FR/Jazzmaster pickup sounds surprisingly vintage and twangy, with a lot of sustain. That Gotoh unit is hands down the best piece of hardware I have used on one of my guitars in terms of design and construction.
    Jsil13, carpenter, zippofan and 15 others like this.
  19. crazydave911
    East Tennessee
    You DO have style :D
  20. guitarbuilder
    Hmm......like a Gretch TK300 met up with Ernie Ball. Love it.
    1979 Gretsch TK 300 Model 7624 Electric Guitar (myrareguitars.com)
    Ernie Ball Music Man Mariposa Electric Guitar - Imperial Black – Chuck Levin's Washington Music Center
