What's on your workbench today?
Discussion in 'Tele Home Depot' started by guitarbuilder, Nov 26, 2011.
  1. telepraise
    telepraise Tele-Holic
    Tampa Bay
    As gorgeous as that top piece is, I think I'd consider resawing bookmatched top caps out of it Eallen. Is it full stable now?
    eallen likes this.
  2. I_build_my_own
    New York
    A mag PU / piezo blender. Slightly more complicated than just hardwiring 2 pickups.
  3. eallen
    eallen Friend of Leo's Silver Supporter
    Yes, it came out of the kiln in November and had been stickerd in my shop since. I hear you on the resaw. I have one that is just under 1-3/4" that I may go that way on.
    A solid walnut tele without chambering is one hefty tele!
    Eric
    dougstrum and crazydave911 like this.
  4. Blue Bill
    Blue Bill Poster Extraordinaire
    I found a set of Craftsman screwdrivers at the local surplus shop for 20 bucks, good excuse to dump out my handy-bag and re-organize:
    Fits, with room to spare. Still weighs less than a Twin Reverb.
  5. epizootics
    epizootics Tele-Meister
    Lyon, France
    Etching a stainless steel neck plate with salt, vinegar and a 12V adapter...
    richa, zippofan, 1bad914 and 15 others like this.
  6. crazydave911
    East Tennessee
    SWEET!
    eallen likes this.
  7. Blue Bill
    Yeah, Epizootics, that's super cool!
  8. Jim_in_PA
    Jim_in_PA Tele-Afflicted Silver Supporter
    SE PA near New Hope PA
    May I suggest you consider doing a dedicated thread to this process? "Enquiring minds want to know..."
  9. DrASATele
    North of Boston
    Yes please! ;)
  10. erix
    erix Tele-Meister Ad Free Member
    Richland, MI
    An ExpressPCB user! I love that program - I'm working on a little arduino-clocked sequencer/reverb/fuzz unit now to run both guitars and moog through.
    I_build_my_own and crazydave911 like this.
  11. mistermikev
    mistermikev Tele-Holic
    phoenix
    what schem you working off of there? I've been looking at similar from diystompboxes and a few others but have settled on just using two distinct preamps and possibly ajusting the output. Either that or trying to reverse my EDA905 preamp but that doesn't sound all that great.
    looks like some tidy work.
    crazydave911 likes this.
  12. erix
    Richland, MI
  13. Zepfan
    Zepfan Poster Extraordinaire
    Horn Lake, MS
    Sorry, I had stated earlier that I was waiting on ordered parts to come in. Some arrived. Now I have to decide what to put them in.
  14. Asmith
    Asmith Friend of Leo's
    East Yorkshire, England
    Progress is slow but steady, I wired most of the power supply and heater wiring today. Still need to hookup the primary side of the transformer and put the artificial center tap on the heaters.
  15. eallen
    That is super cool, yes on a thread of your process!
    Eric
    epizootics likes this.
  16. I_build_my_own
    New York
    A schematic from my brain. I wished myself some functionality then drew it up, simulate it and then on to PCB. Will so how it will sound
  17. otterhound
    otterhound Poster Extraordinaire
    Manheim Pa.
    Gluing up blanks . 3 done already .
  18. Moodivarius
    Moodivarius Tele-Meister Silver Supporter
    Northwest Ontario
    Put together another Zane Guitar Partscaster form the leftovers we acquired. For my oldest some, as per his design. A Jazzmaster in the neck pickup.
    Action quite a bit high. Bridge all the way at the bottom, saddles set so the rear of the strings coming off the “Chigsby” just clearing the rear of the bridge. Can’t lower anymore. I’ll have to shim the neck.
    Scott
  19. epizootics
    Lyon, France
    Cheers guys! I don't know that I'd be the most qualified at making a tutorial about something I've just done for the first time - that was literally my first attempt.
    The process is really simple - sand your pieced down to 400 grit to get a clean & flat surface, mask off anything you don't want to etch with masking tape or paint (or a rejected nail varnish from my wife's stash in my case), cut / scratch whatever shape you do want to etch, clean that up with acetone (I made a pointy wood tool the size of a pen, which I dipped in acetone and used as a precision eraser to make sure there was no varnish left in the areas I wanted to etch), then look into the pile of AC adapters you kept even though the corresponding appliances are long gone (mine was 12v, 2A). Now the fun begins.
    Make a solution of white vinegar and salt. I kept adding salt until it stopped dissolving in the liquid. Get a couple of crocodile clips and a dozen Q-tips. Clip the positive from the adapter to your metal plate. Soak one end of a Q-tip in the solution. Clip the negative to the cotton bit, slightly above the end.
    You can now dab your lines with your Electric Cotton Swab. Be careful not to lift off the edges of your tape in the process. Proceed slowly and methodically. You'll know it's working by the bubbles & sizzling sounds from the swab. WEAR A RESPIRATOR, since the etching will release some pretty nasty fumes. I kept going at it for 15 minutes or so to make sure the etching went deep enough. Be careful not to touch the metal directly with the clip. You'll need to change your swab every so often as they dissolve after a while.
    Once you think you're done, remove the clips, masking tape, give the whole thing a rub with acetone. Rince in water and dish soap. Sand the surface down to whatever grit you want to get to. And...voilà! You etched!
    There are loads of videos on Youtube about this. They range from useful to annoying. This one was OK -
    Overall, it's a very simple process that doesn't require a lot of tools & materials. I can't believe it took me so long to give it a try!
    Blue Bill, hopdybob, eallen and 2 others like this.
  20. maple
    maple TDPRI Member
    north america
    Another member of "team resaw"
