What's on your workbench today?
Discussion in 'Tele Home Depot' started by guitarbuilder, Nov 26, 2011.
  1. Mark Grant
    Mark Grant Tele-Afflicted
    Northern California
    Thank you too much but this is natural oil finish! Just the beauty of mother earth’s finest!
    eallen and crazydave911 like this.
  2. Moodivarius
    Moodivarius Tele-Meister Silver Supporter
    Northwest Ontario
    Strat-O-Tele up and running.
    Humbucker split with 500k push/push Vol pot.
    Nice flamed maple neck.
    I’ll make a black rear control cavity cover, finish the maple block, maybe a rear Strat style cover over the trem route.
    I only had to by the chrome bridge & chrome Tele control cover. Everything else I had lying around.
    Cost me about 50bucks. :D
    Scott
  3. straightlbues
    straightlbues TDPRI Member
    Here is one that just came to life. 1 piece Alder body, Spruce top, and Mini Humbuckers.
    Blue Bill, mkster, SacDAve and 15 others like this.
  4. trev333
    Coolum Beach,Australia
    the dumpster SX is strung up and ready to play.. didn't come up too bad...:)
    before...
    now...
  5. hopdybob
    hopdybob Tele-Afflicted
    netherlands
    that can be, but somehow you manage to boost that beauty without pushing it in the 'to much territory' so i want to close my eyes ore use :cool:
    Mark Grant and crazydave911 like this.
  6. Jackadder
    Jackadder Tele-Holic
    Western Australia
    '54 off the bench and onto the floor....will whittle down the neck over the next week or two, need paint....[edit] just threw it on the scales - 7.08 lb :p
  7. MapleCreekVT
    MapleCreekVT TDPRI Member
    Vermont
    Two projects going right now. Getting ready to start finishing the 2x4 tele. Going to use shellac. Broke 2 drill bits drilling the string through holes with a drill press. What did I learn? Get better bits, faster rotation slow downward pressure. I also ordered a steel drilling jig for the string though holes and ferrules.
    Looking forward to trying it out on this next build.
    next up are some fresh cut router templates I’m going to use on my next build. Not really a telecaster. Sort of a thin line starcaster hybrid. I’ve got an ash blank and am looking for a maple top to close things up.
    bl28, ejphotos, crazydave911 and 4 others like this.
  8. bl28
    bl28 Tele-Meister
    San Diego, CA
    B8DE5C3C-00EB-4F0E-A422-73544D85054C.jpeg Little mock-up. The switch seems to fit even though the cavity is only 1.3” deep. We’ll see once the electronic stage happens.
    I don’t like the clear pickguard - going to go with a mounting ring for the neck pickup instead. I think it’ll be much cleaner.
    Now onto lots of sanding. Then applying the finish. Hopefully the weather cooperates this week so I can spray outside.
  9. Blazer
    Blazer Doctor of Teleocity Ad Free Member
    The Netherlands
    Well, I did a lot of work on my Death dagger.
    DSC02216.JPG I actually went to a paint shop where they mixed metallic red to match the color of that guitar, it now looks kinda pale but it'll darken once the clear coat goes on.
    DSC02217.JPG The spot where I glued the new tip on, again once the clear coat goes on, it should render it invisible (I hope)
    DSC02219.JPG I need to sand this smooth but you wouldn't be able to tell that this neck had been broken once the full process is done.
    About that plate by the bridge, that's a solid piece of Brass which will serve as the new base for the hard tail bridge I'm going to put on there, I made it in such a way that the plate can be taken off and a Kahler could be fixed on there if somebody would want to do so.
    PimR, Zepfan, hopdybob and 2 others like this.
  10. tnt423
    tnt423 Tele-Meister
    StLouis area
    John Nicholas, bl28, mkster and 13 others like this.
  11. trev333
    the jobs are getting smaller....:D
    RogerC and crazydave911 like this.
  12. hopdybob
    netherlands
    eh, why not give it a bellycut and armrest like a strat? less weight and more comfort?
    crazydave911 likes this.
  13. hopdybob
    netherlands
    it looks this was going to happen anyway. ore do i see it wrong that it was not glued completely?
    trev333 likes this.
  14. bl28
    bl28 Tele-Meister
    San Diego, CA
    thought about it - but the weight isn’t crazy right now, and a belly cut would bring out some flaws (bubbles) in the epoxy on the bottom.
  15. Jim_in_PA
    Jim_in_PA Tele-Holic Silver Supporter
    SE PA near New Hope PA
    Finished up an urn for a good friend in the Senegal Parrot community for her beloved Silas (RIP)...this is a "pay it forward" thing for me as the community presented us with a beautiful painting of our bird Tosca (RIP) who passed away last year.
    Oh, and there's a bench on my bench...Geoffrey Noden's new "Craftsman" bench package. I'm already a Noden Adjust-A-Bench user and have been for years and had the opportunity to put together a pre-production kit and vette the instructions. This new adjustable height bench will be supporting a down-draft sanding table as well as serve for additional small assembly space. Clearly, I felt compelled to personalize it. :) The difference between this version and the original is that the original is all steel for the base. The Craftsman package provides steel components that are mated with woodworker supplied panels for lower cost and additional flexibility. The capacity and height adjustment parameters are the same. I'm a huge believer in having a workshop surface at the optimal height for whatever is being done ... easier on the back and more accommodating to the task.
    eallen, nickhofen, tnt423 and 4 others like this.
  16. Jackadder
    Western Australia
    It's a boast post with decent quality pic.....
    The neck is a hefty chunk but feels great so I'll stay with it for now....still have to run some CA into the slots and level the frets but the action is low enough as is so there's no hurry...
    I'm not particularly keen on the tobacco burst look but what else tarts up a '54? Might have a crack at a burst with prooftints....
    bl28, nickhofen, mkster and 12 others like this.
  17. Jackadder
    Western Australia
    Although it's obviously a 2 piece neck I put a walnut plug in for looks, the birdseye roasted maple goes alright....
  18. crazydave911
    East Tennessee
    TreblaNitram, trev333 and Zepfan like this.
  19. PimR
    PimR TDPRI Member
    netherlands
    looks great, W....
  20. trev333
    all glued up and ready to tip toe through the tulips...:D
    John Nicholas and Jim_in_PA like this.
