What's on your workbench today?
Discussion in 'Tele Home Depot' started by guitarbuilder, Nov 26, 2011.
  1. CraigB
    CraigB Tele-Afflicted
    Central Coast of CA
    After a couple rounds of tung oil, it's starting to have a nice glow. One more application should do it
    It also has a silky smooth feel. I think I know what I'll be using on my next neck!
  2. crazydave911
    East Tennessee
    Very nice Craig :cool:
    CraigB likes this.
  3. eallen
    eallen Friend of Leo's Silver Supporter
    Very nice work Craig!
    Eric
    CraigB likes this.
  4. Jake Nelson
    Jake Nelson Tele-Meister
    Alexandria, MN
  5. roffe
    roffe Tele-Meister
    Stavanger, Norway
    Routed the neck pocket and finished spindle sanding the perimeter. I stuffed some epoxy into the worm holes after the picture. Now to find my pickup template... or just make a new one.
  6. imbunche
    imbunche TDPRI Member
    Chile
    Me yesterday.
    I won't be able to work on this for a couple of weeks[​IMG][​IMG][​IMG]
    Sent from my FLA-LX3 using Tapatalk
    Macrogats, Zepfan, Barncaster and 7 others like this.
  7. Gipper
    Gipper Tele-Meister
    Belleville, Illinois
    Working on a blank for a new build
    Brian
    Macrogats, Zepfan, Barncaster and 6 others like this.
  8. Jake Nelson
    Alexandria, MN
    couple blanks ready for the future
    Zepfan, eallen, Barncaster and 5 others like this.
  9. Ripthorn
    Ripthorn Tele-Afflicted
    Austin, TX
    Just a couple finished necks
    And matching cavity covers from fretboard leftovers:
    Next up: truss rod covers, level sanding the sealer, and getting some clear on the bodies, if the weather cooperates.
  10. Barncaster
    Northern California
    LOTS of building going on here! Let’s see some dedicated threads for these beauties!
    erix, crazydave911 and Jake Nelson like this.
  11. Ripthorn
    Austin, TX
    Barncaster likes this.
  12. roffe
    roffe Tele-Meister
    Stavanger, Norway
    Tried a little old pine carving just to see how it went. I know how different the light and dark areas can be in hardness, but this piece is ridiculous. It’s like carving plywood. I’m getting a flap disc.
    CraigB likes this.
  13. devrock
    devrock Tele-Meister
    New England
    How are you getting such perfect ferrule holes on the back? Mine are usually a mess.
  14. Ripthorn
    Austin, TX
    On this one, I marked them on the front and drilled half way through, then I used a peg on the flipped over body to make sure they were lined up well. I actually have a milling machine that I usually use to make a steel guide plate so that they are straight to within .001-.002", but on these I am at about .01" just due to the method.
  15. Zepfan
    Zepfan Doctor of Teleocity
    Horn Lake, MS
    Got to work on this some. Results so far are:
    1. There's a sine wave going through the whole board from the acoustic preamp. Guessing that's from the interaction between the preamp and the Distortion knob.
    2. Even though everything is supposed to be "True Bypass", it really isn't. gotta go back through this and find out what's going on with that.
    3. The spring Reverb works if you tap the board box. Not enough signal boost through the Piezo to spring actuator. Maybe if I bypassed the preamp from the Distortion and straight to the Reverb Piezo it would work? Maybe not.
  16. CraigB
    Central Coast of CA
    Damn, it's a little warm here, warmer than we're used to anyway. It was 106F on my sideyard at around 11:00 this morning. Final coat on and stuck the tube chart inside.
    Put the handle and rubber feet on, installed baffle and speaker and mounted chassis
    Slapped on the back panels
    And took it out in the sun for a couple shots
    Gipper, nosmo, GoKart Mozart and 11 others like this.
  17. eallen
    Wow Craig. That is looking sharp! Love the workmanship.
    Eric
    crazydave911 likes this.
  18. Freeman Keller
    Craig, I love that amp.
  19. Captain Nutslot
    Captain Nutslot Friend of Leo's Silver Supporter
    Rochester, NY
    E62B67B8-D950-4A49-9F0F-32A7A0EACFFF.jpeg E97777A6-3546-4345-9E76-F75C4E78AC2E.jpeg 31396F78-D14B-4F56-91D7-176CD3DAD160.jpeg
    Good luck me :eek:
  20. CraigB
    Central Coast of CA
    Thank you both! Now out to light the BBQ. That should be fun to stand near...It's only 95F out right now :lol:
    eallen likes this.
