What's on your workbench today?
Discussion in 'Tele Home Depot' started by guitarbuilder, Nov 26, 2011.
  1. Zepfan
    Zepfan Poster Extraordinaire
    Horn Lake, MS
    This is the second time to convert one of these type pickups to a Firebird and they work out great. Good idea on the varnish, I'll keep that in mind.
  2. I_build_my_own
    New York
    1.8mm veneer on the router sled- and 8 clamps to hold it :D
    7B1247F9-F8CB-4C05-AB84-7B2192A27A85.png 614F6EC1-A336-45FA-AA53-294465D55F09.png
  3. trev333
    Coolum Beach,Australia
    Did the neck pocket rout and a deluxe curve for a nice smooth feel, this morning.... while building up some coats of D/oil on the neck... shiny..:)
  4. Moodivarius
    Moodivarius Tele-Meister Silver Supporter
    Northwest Ontario
    Got the body wet sanded & polished today.
    This evening we installed most of the hardware, minus frets, nut & VOL pot. Still waiting on order to show up on the mail.
    The heartwood of the black ash wasn't perfectly stable. We glued it in on the blank build. Still showed through after level/wet sanding. Perfectly level & solid, but looks defective. Relic!
    Added the strap buttons after taking the pics.
  5. crazydave911
    East Tennessee
    I fully realize with a kid COOL rules the day but was there any method to the madness of that pup selection. Plus I REALLY like that color,greens are all to rare around these parts lol
  6. I_build_my_own
    New York
    When the socks are matching the sweater...
  7. LeftFinger
    LeftFinger Friend of Leo's
    Saskatchewan
    That's called drool worthy :D
    Barncaster and crazydave911 like this.
  8. eallen
    eallen Tele-Afflicted Silver Supporter
    Man, that is just gorgeous! Natures beautiy is hard to beat@
    Eric
    crazydave911 likes this.
  9. Jim_in_PA
    Jim_in_PA Tele-Holic Silver Supporter
    SE PA near New Hope PA
    Dang...that's eye candy!
  10. mefgames
    mefgames Friend of Leo's Platinum Supporter
    North Bay, Ca
    IMG_7676.jpg IMG_7671.jpg IMG_7673.jpg Case Update, foam and fur lining today, still haven't decided on how to finish up the 2 side compartments.
    CraigB, Macrogats, brandonh and 12 others like this.
  11. Meteorman
    Meteorman Tele-Holic
    State College PA
  12. I_build_my_own
    New York
    Yes, just double sided tape, but not really the strong “carpet tape” since I want to get the veneer off in one piece. Using this one for veneers. C9D5C465-E0ED-421E-AC35-1ACA5D850C21.jpeg
  13. crazydave911
    East Tennessee
    A sanding day :rolleyes: and yes, have to vaccum every two or three days and YES, Lowe's and the Despot love my sandpaper purchases (send me Christmas Cards they do) LMAO
    Dave
    CraigB and Zepfan like this.
  14. Moodivarius
    Northwest Ontario
    Fretted late afternoon & wired controls this evening.
    All done!
    There was no reason why we put the P90 in the middle. Just thought it was the only place while keeping the standard Tele pickups.
    The Gilmour mod with the push-pull allows the neck to be on with the bridge, or all 3 pickups when in the second position of the 5-way switch. Lots of different sounds. Swis Army Guitar.
    Kind of a unique animal.
    marc2211, CraigB, Macrogats and 6 others like this.
  15. crazydave911
    East Tennessee
    I LIKE it!!!!
  16. crisscrosscrash
    crisscrosscrash Tele-Meister
    Montreal
    Just finishing up the final set-up on this JM style electric baritone ukulele -- it's got a few idiosyncratic additions, like onboard fuzz, and a momentary kill switch...
  17. GunsOfBrixton
    GunsOfBrixton Tele-Afflicted
    Rochester, NY
    Not guitar related and not on my bench but some of you may like this. The roof on our 2 car garage is sagging. The main reason is that the previous owner had removed 3 of the rafter ties when either fixing or installing new garage doors. The rule of thumb is a full length rafter tie every other roof rafter. The job of the rafter ties is to hold the opposite walls together (the rafter ties are under tension) Not having enough allows the roof to sag and the walls to bulge out at the top. The fix is fairly simple. Jack up the roof and pull the top off the walls back in. Once a the walls are a little past vertical, install the new rafter ties and re-secure any that have pulled away. I am also over engineering the fix a little. I am adding 2 1/2" cables with turnbuckles. That should hold it together. Some pictures so far.
    The roof.
    Rafter ties pulled away from roof rafter.
    First half section of one of the cables.
    Turnbuckle assembly
    No using the garage right now.
  18. trev333
    set up a bridge today..... and finished the pickup routs and wiring holes... getting there...
    I use hat elastic pulled up nice and tight to align my bridges .... easy to work with, keeps tension if you move the bridge, no need to have tuners in...a rubber band holds it into the nut slots...
    I hold it with a few pickguard screws at first before drilling for larger ones, in case I want to micro adjust the bridge placement..... I put my final screws in after I string it up and check intonation/where the saddles sit ... I like them more forward than right against the back as the bass saddle can be sometimes....
    I'm using up parts, I'll give this guitar away to a teen I know...... I don't think he'll care if it isn't a 3 barrel bridge..;)... I'm cutting this one down along the line of the back of the pickup hole and putting 2xp90's in it with the bridge pu angled....
    CraigB, Barncaster, RiversQC and 3 others like this.
  19. trev333
    4 pounds even.... lightweight ...:)
    CraigB, Barncaster and Jim_in_PA like this.
  20. eallen
    Cutting up some curly maple and walnut for fretboards, resaw, plane. Cut out a couple curly maple, walnut and cherry necks after routing for trussrods. Glue some necks together, cut headstock to thickness, and transition to fretboard. Deciding what neck/fretboard wood combo will look best on a couple ambrosia maple bodies and a cherry body. [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Eric
