What's on your workbench today?
Discussion in 'Tele Home Depot' started by guitarbuilder, Nov 26, 2011.
  1. Davecam48
    Queensland Australia
    This thread totally non-guitar related but was certainly done on my workbench!
    Several years ago when my wife and I returned from a China trip we brought back some of her small household and personal items including a pair of stainless steel scissors. These have to be the most excellent scissors I have ever used and as well as a great cutting ability they also have a built in bottle opener and a toothed grip for stubborn screw-top lids. The best part is their cutting ability which is brilliant as they easily cut cardboard to the very finest paper to crushed velvet.
    Sadly one of the handles broke off rendering them impossible to use. Not being able to use them made me realize how much we used them.
    Anyway after SWMBO put them in the rubbish to dump them I rescued them and used the good handle to make a pattern for the pin router and I cut out a new handle from some scrap red gum which is just a tad softer than high tensile stainless steel. I was lucky that the slot required to fit the steel handle stub into the new handle is almost a perfect fit to a slot cut by a fine metal cutting disk sander blade, so one cut with the angle grinder and some JB epoxy and Bob was my Uncle, SWMBO thinks they're good and I had a modicum of fun!
    DC
  2. LuckyJinx
    LuckyJinx TDPRI Member
    Portsmouth, Shire of Hamp
    (this is all hearsay, I've only done one refret and I probably should redo it because it could have turned out better)
    What radius is your fretboard? You want the wire slightly overbent so if any part of the fret is being pushed out of the board by the metal spring, it is the middle which is being held in more firmly by the wood. There's fewer barbs counteracting that at the ends, so you might have fret ends sticking up slightly. That curve is probably good for 10" radius and up, but you probably want to bend the wire a bit more for 9.5".
    Unless it's stainless, in which case you want it to match the radius exactly because if you overbend it it is strong and springy enough to pop out despite the middle barbs trying to hold it in.
    Mr_Q likes this.
  3. guitarbuilder
    guitarbuilder Telefied Silver Supporter
    It depends on what your fretboard radius is. If it is less than 10, I'd build a jig to overbend it. If you don't want to make an elaborate one, you could probably get away with 3 strategically placed bolts, nuts and washers in a piece of wood. Another thing that would work could be a round circle of wood with a groove in it.
    nickhofen and Mr_Q like this.
  4. Mr_Q
    Mr_Q Tele-Meister
    Iowa
    It's 9.5, so I'll build a bender and get it right.
    Sent from my SM-T810 using Tapatalk
  5. guitarbuilder
    If you plan on doing more of this stuff, then a bender is the way to go.
    Mr_Q likes this.
  6. Bugeater281
    Bugeater281 Tele-Meister
    Omaha
    Not terrible for my first paint job.
    Will deff lacquer work over dupli color perfect match? And how soon can a spray the clear?
    83FE7B6B-4616-4218-A655-220841094AE1.jpeg 8FC0C28A-5F2C-415B-9B8D-A09C2DF76B72.jpeg
    Captain Nutslot likes this.
  7. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    I wouldn't use Deft lacquer at all. I used it on my first couple of builds several years ago, and it never really got hard.
    jkingma and Bugeater281 like this.
  8. Freeman Keller
    Freeman Keller Tele-Afflicted
    I hope I didn't lead you astray LOL. That might work but in my opinion is marginal - I would rebend it. I built my first fret wire bender out of some bearings and odds and ends and set it up for the two radii that I normally use (10 and 14 for 12 and 16 inch boards) but then I found myself wanting to do others so I just broke down and bought the StewMac thing. It has worked well but takes a couple of minutes to set and check each time)
    Mr_Q likes this.
  9. Zepfan
    Zepfan Poster Extraordinaire
    Horn Lake, MS
    If the Deff is Acrylic Lacquer, it will work. The Dupli-Color clear for wheels works great. I've heard bad things about their regular clear, but don't know for sure.
    tone57 likes this.
  10. RolandG
    RolandG Tele-Meister
    Nice to see. It always amazes me when people don’t make these things themselves
  11. nnieman
    nnieman Tele-Meister
    ontario, canada
    Looks good
    I’d use watco from Home Depot.
    Let the duplicolor dry for a week or two before clear coating it.
    Nathan
    Bugeater281 likes this.
  12. nnieman
    ontario, canada
    06A9E070-1EC0-4C19-A4CB-76583322664E.jpeg A2345E55-445F-4956-A9A2-D28E73B95B56.jpeg 350EF4EF-F5EC-41D2-828F-506FF47A25AA.jpeg 9E7112DD-1C55-468A-8756-EF856AA6BCCB.jpeg
    Too windy & rainy to spray today so I made some pickguard.
    Nathan
  13. eallen
    eallen Tele-Afflicted
    How soon depends on what the color and clear coats are. If it is lacquer over lacquer then 30 minutes after the color coats area finished. There is no reason to wait lacquer over lacquer. IMHO.
    Eric
  14. Zepfan
    Horn Lake, MS
    tone57 likes this.
  15. YALCaster
    YALCaster Tele-Meister
    Tulsa
    Some new bodies
  16. Moodivarius
    Moodivarius Tele-Meister
    Northwest Ontario
    Filed the nut & sanded saddle down, to get the action close to the Fender's recommended setup.
    Pierce, zippofan, mrz80 and 7 others like this.
  17. Recalcitrant
    Recalcitrant TDPRI Member
    Philadelphia
    Basswood in ReRanch (Gretsch) Orange. Oh yes, it's soft! Self-relicking. And soaks up water-- seal your screw holes! This swell flattened out after drying a few days. IMG-0439.JPG IMG-0438.JPG jr1.jpg
    zippofan, mrz80, TreblaNitram and 8 others like this.
  18. nnieman
    ontario, canada
    tone57 likes this.
  19. tone57
    tone57 Tele-Meister
    Atlanta / Lawrenceville
    Well, after that pickguard, this is a bit underwheming,
    but for me it was a bit of a breakthrough.
    The PuP rings and Plates were too thick, and the amount of sanding prohibitive.
    I dread resawing on my table saw, just absolutely terrifies my fingers..
    but i made a jig, sawed out the middle 1/8" and that leaves me with 2 3mm plated to use.
    the parts come off the machine faster ( not really an issue, not like i am manufacturing or anything ),
    and the amount of dust is way less, plus thw pots and switches will fit correctly.
    anyway, cut some in Rosewood and Birdseye today.. The Flame Maple was from an earlier run.
  20. Macrogats
    Macrogats Friend of Leo's
    Auckland, New Zealand
