What's on your workbench today?
Discussion in 'Tele Home Depot' started by guitarbuilder, Nov 26, 2011.
  1. I_build_my_own
    New York
    nickhofen likes this.
  2. Freeman Keller
    Got the OM bound today. I had bent the binding back when I did the sides and just clamped them in a mold until now. Put a couple of coats of shellac on the spruce to try to keep it from blowing out during the route (and keep tape from sticking too bad). This will be bound all in rosewood with the top getting four little purfling lines, the back a single maple line. Routed the channels
    Installed the tail graft. I've got a few scraps of Brazilian left and figured I'd better use them before I die.
    I do all my binding with thin CA. I've tried Duco and acetone and wood glue and medium CA, haven't been happy with any of them. I like to completely install and miter the binding dry, getting it to fit the channels perfectly. I tape in in place leaving a gap between each piece of tape. Put a drop of CA at each gap, it wicks into the seam between the binding and body. Then I pull the tape and go back and run a bead of CA all around the binding - top and side. Its kind of like a welder clamping two pieces together and tack welding them, then pulling the clamps and running his bead.
    The respirator is because I have become very sensitized to CA. I hate the stuff but I can't live without it
    Here is the guitar after the tape has been pulled and the entire binding glued
    A little scraping and sanding
    And the top
    zippofan, eallen, Barncaster and 11 others like this.
  3. nickhofen
    nickhofen Friend of Leo's
    HELLAS, Land Of Heroes .
    Nah,I bite a little and it taste like wood!
    :D
    crazydave911 and John Nicholas like this.
  4. John Nicholas
    John Nicholas Friend of Leo's
    Poughkeepsie, NY
    This guitar looks amazing!
    I love your technique for biding using CA.
    Does the respirator cut out the smell? Does it prevent the fumes from burning your eyes?
    I try very hard not to use CA. When I do, it's mostly outdoors and I try to never breathe the fumes...
    CraigB likes this.
  5. epizootics
    epizootics Tele-Meister
    Lyon, France
    First neck carving ever...Had to resist reducing it to a twig with my spokeshave...
  6. Freeman Keller
    Thank you. The theme for this guitar is tastefully simple. Nice woods (the spruce has some great silk and a pretty nice tap tone), minimum bling, just classical simplicity.
    The respirator eliminates some of the fumes but not all - my asthma kicked in pretty badly last night. I keep looking for a better way to do this but the method is so darn effective.
    John Nicholas likes this.
  7. CraigB
    CraigB Tele-Afflicted
    Central Coast of CA
    Beautiful work. I love the volute, very sharp and classy!
  8. CraigB
    Central Coast of CA
    Dang sorry to hear about the asthma Freeman. That guitar is another work of art, Sir!
  9. Macrogats
    Macrogats Friend of Leo's
    Auckland, New Zealand
    You certainly are a true artist Freeman.
    CraigB likes this.
  10. I_build_my_own
    New York
    :twisted:Alert CNC content :D Board #3 up and running. 13 additional inputs and 4 outputs. Always excited when the blue light comes on and UCCNC software speaks to the board.
  11. mistermikev
    mistermikev Tele-Holic
    phoenix
    wow is that ever a beauty build!
    CraigB likes this.
  12. Macrogats
    Been chipping away at my Model1 revamp over the past few days. Cap glue up went ok, required a bit of glue and sawdust filling around some edges where the old top was still a little rounded. Next I gave the top a 3/8ths round over. Today I used some extra hard wood filler on certain spots, and unfortunately had to sand down the entire back, as it had received too many dings, dents and scratches from the glue up and various other things being done. So she’ll be a complete refinish now.
    Also got the neck pocket piece cut out, and she (neck) fits like a glove. Next step will be to sort out the pup cavity and a new mounting plate. Did another bridge mock up, and have decided to go with a regular tailpiece as this old trapeze style one is not designed for rounded bodies.
    Here’s a few pics. Old back colour was a walnut stain with a hint of maple and poly finish. Going to try to replicate that. For final finish of the guitar top - imagine it basically matching the headstock. Second full pic shows colour better.
    So essentially, it’s a Cypress body with 1/4 inch Pine cap, laminated with Birdseye Maple veneer.
  13. Randy Jones
    Randy Jones TDPRI Member
    San Francisco
    C04A35D4-B2AF-4FF9-B8F6-A80D96CBB2AA.jpeg Inlayed the head plate on my mandolin build.
    eallen, Barncaster, Mr_Q and 5 others like this.
  14. Mat UK
    Mat UK Tele-Afflicted
    London, UK
    A sunburst would look great on those... or maybe Candy Apple.
    I_build_my_own and CraigB like this.
  15. mefgames
    mefgames Tele-Afflicted Platinum Supporter
    North Bay, Ca
    Finish is done, went natural with Tung oil. Still waiting on delivery of my pickups, but it's getting there.
  16. YALCaster
    YALCaster Tele-Meister
    Tulsa
    Slowly been working on this the last couple months
    (If you guys wanna see a build thread when it’s done just let me know :))
  17. Freeman Keller
    A little geometry. With the binding in place I can put the neck on and make sure everything lines up. Floss the cheeks
    Level the upper bout (there is sand paper on the bottom of the carpenter's level)
    Very slightly overset, but I would rather have that than under. I'll have another chance after its been fretted
  18. mefgames
    North Bay, Ca
    Did you build the body ? Are you building the hockey stick neck ? There's some interest in these over at offset guitars. You might find some useful info over there. I built the Electric XII and found the only place to get the pickups is Curtis Novak, he does great work, unless Fender will sell you some from the re-issues the are now making. Keep us posted !!
    YALCaster likes this.
  19. YALCaster
    Tulsa
    Had warmoth make the neck, my only complaint is the overhang (never liked overhang). I have the pickups, the only thing I need is the paint!! Can’t wait to get it done.
  20. maito
    maito Tele-Meister
    Finland
    Stratotone inspired thingy, im thinking black or sunburst. Pickgurd will be pearloid too.
    Anyone seen new short type tailpieces? I cant cant seem to find any reasonably priced.
