What's on your workbench today?
Discussion in 'Tele Home Depot' started by guitarbuilder, Nov 26, 2011.
  1. Pullshocks
    Pullshocks TDPRI Member
    Seattle
    Finally getting back to my thinline project which has been dormant for over a year. The neck needs to have the screw holes re-drilled. I'm debating whether to go with threaded inserts wile I'm at it.
    Either way, I need to get a good center line on there so I can lay out the holes accurately.
    I clamped the neck between a couple square, straight boards. They are 1.5" tall, so they stand taller than the neck. They also hold the neck in a level position.
    At the heel end I used a 1.125" board to make a center mark.
    At the peghead end, I used a narrower piece to get a center mark on the peg head
    To draw the line, I clamped the straight edge at the peg head end.
    By using the long straight edge the center line is very accurate on the heel.
    TigerG likes this.
  2. Macrogats
    Macrogats Friend of Leo's
    Auckland, New Zealand
    Whammy bar on a CBG. Brilliant!
  3. nickhofen
    nickhofen Friend of Leo's
    HELLAS, Land Of Heroes .
    What do you think that cause the problem? Do you use mach 3?
  4. I_build_my_own
    New York
    Look at that volute!!! Mark you make me proud! I am sure you will use shielded wire on the pups, right?
    Mark Grant likes this.
  5. Clint Walker
    Clint Walker Tele-Meister
    Killeen, Texas
    Hey Nick! I am using Fusion360 for my CAD/CAM...my CNC is the Xcarve from Inventables...I think I was getting too aggressive (more than usual) with my DOC and speed...I believe the drive belts slipped...I have since gone through the machine and tightened everything up...have had the machine for a year...it has been great...just need to do some routine maintenance.
    nickhofen likes this.
  6. Zepfan
    Zepfan Poster Extraordinaire
    Horn Lake, MS
    Thanks. I made it out of a heavy duty door hinge, Strat trem arm and spring claw from my parts bin and some springs from Lowe's. The bridge is a bolt that rotates inside a few nuts to simulate a rollor bridge. It works okay as long as everything's lubed well, but it could be better.
    Thought about mounting an entire Strat tremolo assembly on the rear edge of a CBG like one of those travel guitars.
  7. Mark Grant
    Mark Grant Tele-Afflicted
    Northern California
    Pre-assembly carcass shots of Slapadabass 5 AWS. Knocked out the cavity routes on the back of the body. Just a few holes to drill now. I'll keep working on the oil/wax finish over the next week. Almost to the end of a prototype build and it looks like all parts will make the cut! I'm thankful for that every time! Have a good turkey day everybody.
  8. erix
    erix Tele-Meister Ad Free Member
    Richland, MI
    Thanks for this!
  9. John Nicholas
    John Nicholas Friend of Leo's
    Poughkeepsie, NY
    Looks totally amazing! Love it!!
  10. BC-Rush
    BC-Rush Tele-Meister
    West Virginia
    Lots of glitter. Can't seem to clean it all up! IMG_20171123_193301734.jpg IMG_20171123_195839500.jpg
  11. Bugeater281
    Bugeater281 Tele-Meister
    Omaha
  12. GunsOfBrixton
    GunsOfBrixton Tele-Afflicted
    Rochester, NY
    Spent some time in the basement today. Cleaned up the CNC and gave it the once over. Fired it up and planed a walnut blank down to 1.5" and the matching top down to about .25".
    Mangled one hold down clamp. The machine went exactly where I told it to go. :)
    Also had the computer reboot itself due to an error. (before I started doing anything, so no harm) It is an old Packard bell. Time to do an upgrade. Will also probably go to using USB instead of the parallel port. I'll pick up one of these. http://cncdrive.com/UC100.html
    I want to also check out their software (AS a replacement for Mach3) http://cncdrive.com/UCCNC.html.
    More and more people seem to be moving to it.
    Tomorrow I plan on planing down another blank , swamp ash. Then it will be on to cutting out the thin line cavities on them.
    guitarbuilder and TigerG like this.
  13. Barncaster
    Northern California
    koolaide likes this.
  14. JackL
    JackL Tele-Meister Silver Supporter
    Monroeville, PA
    I can't imagine working with maple for the body. I've made maple necks but maple seems too dense for a body.
    JackL
  15. 10orgtr
    10orgtr Tele-Meister
    western PA
    "Lots of glitter. Can't seem to clean it all up!"
    I flaked my bike in '09 on the back porch. I'm still finding flake!
    Cheers,
    Woody
    BC-Rush likes this.
  16. koolaide
    koolaide Tele-Holic
    south carolina
    You could always call the local strip club, I'm sure, I mean I guess someone there would know how to clean up excess glitter.;)
    BC-Rush likes this.
  17. BC-Rush
    West Virginia
    Hah! That's what I originally had in mind, but I wanted to try out "glitter" in a spray can as an easy alternative to metal flake. I'm thinking summer 2018 I'll do a build and use the real deal DPP.
    LOL!
    Barncaster and koolaide like this.
  18. Reckless Rat
    Reckless Rat Tele-Meister
    Picture the scene: 60+ years hence, and BC-Rush has quietly expired. A doctor is examining the body, and a detective walks in.
    Detective: So, what did you find, doctor?
    Doctor: Well, it seems that the high living and good times finally caught up with him. Oh, and I found all this pink glitter in his buttcrack
    Detective: Damnit! This can mean only one thing! The Killer Strippers strike again!
    Doctor: Nah, he was a luthier.
    Detective: ....whut?
    :D
  19. John Nicholas
    Poughkeepsie, NY
    ^ Now that one made me laugh out loud!!
  20. Macrogats
    Wow! That's freaking awesome! Very nice.
