What's on your workbench today?
Discussion in 'Tele Home Depot' started by guitarbuilder, Nov 26, 2011.
  1. Jupiter
    Osaka, Japan
    Welcome!
  2. Barncaster
    Northern California
    Hi Martin,
    Feel free to PM me with any questions concerning your pup winding. The guitar looks great.
    Rob
  3. Scatter Lee
    Scatter Lee Friend of Leo's
    follow the buzzards
    Thanks, sure I could make a lefty
    24 track likes this.
  4. 24 track
    24 track Doctor of Teleocity
    kamloops bc
    thank you, I may be in touch with you, Keep on making beautiful guitars.
  5. martin_smith
    martin_smith Tele-Meister
    Perth, Australia
    Thanks, I appreciate the offer.
    I've read the thread a couple of times now and I think everything's falling into place in my head - I have to say it's the best humbucker tutorial I've come across, many thanks for writing it.
  6. u-mix
    u-mix TDPRI Member
    Russian,Stavropol'
    sometime it will be solid body fretless bass wilth piezo and coil sensor...
    [​IMG][​IMG]
    DrASATele, kissTheApex and 24 track like this.
  7. RickyRicardo
    RickyRicardo Friend of Leo's
    Calgary, Alberta
    A unique shape and that is some upper horn. I don't think I've heard of "upper horn heavy". What's the balance going to be like?
  8. telemcCaster
    telemcCaster Tele-Holic
    Michigan
    Twilight
    Blue Bill, DrASATele, Maxbra and 8 others like this.
  9. Jupiter
    Osaka, Japan
    WOW! Alternate universe stuff right there!
    telemcCaster likes this.
  10. mPacT
    mPacT Tele-Holic
    Burbank, CA
    How do like that book? I'm thinking about getting it for everything else besides making the pickup winder.
  11. Tony Done
    Tony Done Friend of Leo's
    Toowoomba, Australia
    Soundport:
    This is my Colombian requinto, a bit of a clunker but of sentimental value. The idea of the sound port is to increase the brightness perceived by the player. I haven't tested it yet, but I don't expect it to have much effect on what the audience might hear. If I ever played for an audienc, that is.
  12. Moldy Oldy
    Moldy Oldy Tele-Meister Ad Free Member
    Mission Viejo, CA
    After struggling with templates and router bits that were never long enough on my Elpy build, plus looking at some of preeb's later threads, I decided I need a pin router. They're too expensive, plus no room for a real one in the shop. Ran across a guy on the Tube who made one that raises and lowers pneumatically. I thought "you can do that?" Yup. So I just finished my version. Clamps to my router table, and the "pin" is just a round bar clamped in the collet of the router under the table. Pneumatic footswitch makes it go up and down.
  13. metecem
    metecem Friend of Leo's
    berlin,now in Istanbul
    Blimey, this is nice. I'd so much love to have a small pin router :(
  14. OpenG Capo4
    OpenG Capo4 Friend of Leo's
    Athens, GA
    My friend brought by this "El Degas" bass that was very weak sounding. He has a gig Sunday so he needed it fixed pronto. Popped the pickguard off and checked it with the multimeter, got good connections all across the pots and jack. Couldn't get a reading on the pickup.
    Popped the cover apart, removed the coil, saw that one of the leads had a break in the solder to the coil wire. Tried and tried to re-solder it. This is tiny wire, must be 45 or 46awg. Finally got it soldered back on. Then it broke again while I was trying to tape it up. There was not enough lead left after the break to re-solder it. So I ended up rewinding it.
    This is a cool little pickup. I should have got more pics of how it's constructed. I thought it's be a mini-bucker. It's really a single coil with a steel blade that goes thru the middle of the coil. On either side of the blade are bar magnets that the polepieces screw into. So you have polepieces outside the coil that are North on one side and South on the other side. But it's a single coil so it still hums a bit.
    I plugged it in and played it and it sounds pretty good thru my little 50 watt solid state bass amp. Gonna wax pot it this evening. Wanted to make sure it works and sounds right first.
    Barncaster likes this.
  15. pjohnny
    pjohnny TDPRI Member
    Minnesota
    Got this fir plate cabronita mocked up in the shop. (Those knobs are just placeholders) I'm thinking barn red might be the way to go. :)
    I've got some folks telling me to relic it... but I'm not sure if I want to go down that road. I've got some wood hardener that I'm planning to use before finishing.
  16. Captain Nutslot
    Captain Nutslot Friend of Leo's
    Rochester, NY
    Some sort of little serving/condiment platter for the kitchen table? made from a slice of a cherry tree... Need to mount it on a branch slab or somethin... Cut with a chainsaw , ran through a planer, sanded and wipe on poly.
  17. nickhofen
    nickhofen Friend of Leo's
    HELLAS, Land Of Heroes .
    I believe the rest of that cherry wood is going to be a beautiful guitar,right?:D
    DrASATele likes this.
  18. nickhofen
    I am addicted to that thing and I am trying to find something else to re fret.
    I miss my dog for a second , I believe Cookie ( my dog's name) will look cool with some frets on, nah she is beautiful either way!!!
    LeftyAl and Captain Nutslot like this.
  19. I_build_my_own
    New York
    It looks a bit brutal but it is a clever idea. Are you sure that lever is long enough and you have enought momentum ;)
    metecem likes this.
  20. dtermined2play
    dtermined2play Tele-Afflicted
    Spartanburg,S.C.
    I built this from a hundred year old door and some legs that came from a tile top table that had seen better days.
    [​IMG] [​IMG][​IMG][​IMG]
    Blue Bill, DrASATele and nickhofen like this.
