What's on your workbench today?
Discussion in 'Tele Home Depot' started by guitarbuilder, Nov 26, 2011.
  1. nickhofen
    nickhofen Friend of Leo's
    HELLAS, Land Of Heroes .
    Graig
    First I put it in the oven and rise the tempreture from 0 degrees to 195 Celcius that took half an hour then roasted for 1hour ang leave it in the oven to come at a temperature that I can touch it with bear hands, for about another 1 and a half hour.
    Then gradually rise the temprature again at 215 Celcius for 35min and let it cool until it was cool enough, another three hours.
    The wood was stable because it was dry enough, I had it in my workshop for couple of years and it was dry already when I bought it.
    I could have left it in the oven for more than 35 minutes, at the second round but I didn't want the neck to be very dark.
    In the whole procedure I follow the instructions that a woodworker, who makes furniture, gave to me a couple of years before.
    The first step is very critical because if the wood is not dry enough, can split.
  2. OpenG Capo4
    OpenG Capo4 Friend of Leo's
    Athens, GA
  3. CraigB
    CraigB Tele-Afflicted
    Central Coast of CA
    Thank you Nick!!!
  4. MadJack
    MadJack Friend of Leo's
    ꓶꓞ ʻɹǝๅpuɐꓛ
    nickhofen, that should be a beautiful neck.
    It's been raining off and on all day, everyday after I started working on this cab Tuesday. I was able to move stuff around in my garage to at least put together the cab and start using it. I finished the back and made some temporary braces to hold the speaker baffle in place till I can make the front perimeter trim, as used on the Orange PPC Series Cabs. The speaker jack was done from the same scrap of sheet metal as the 2 X 10" cab in my previous cab build. The Back is the same as the previous build also. I swapped the WGS Retro 30 that was on the baffle board for the WGS Reaper that I had in the Kustom Defender 112.
    I'm using the cab with the Orange Micro Terror seen here:
    The Lil' Night Train Night Train is running the other cab, which I did the trim and dressing work, a co-worker built the cab. That cab houses a 30 watt, 10", 16Ω Weber AlNiCo Blue Pup.
    The cab is a slight bit "ring-y", which I attribute to the (temporary) floating baffle, a few air leaks and the lack of Tolex/Vinyl covering. The floating baffle and air leaks will be resolved when I finish the front trim.
    The sound is a marked improvement over the Kustom cab. The Kustom being too small, main body made of 5/8" particle board and the speaker baffle is some mystery 3/8" plywood. No wonder it sounded as poor as it did. Eh, I got it cheap.
  5. Rich Rice
    Rich Rice Poster Extraordinaire
    Chicago 'Burbs
  6. R. Stratenstein
    Loganville, Ga.
    That is a gorgeous piece of Claro, Rich. Looking forward to seeing it turn into a guitar!
  7. R. Stratenstein
    Loganville, Ga.
    Not much more left to do now, is there Eric?
  8. Mightyaxeman
    Mightyaxeman Tele-Afflicted
    Pennsylvania
    Still working on the paint job, but laid out some parts to get a feel of the overall look. I like it so far.
  9. Mightyaxeman
    Pennsylvania
    Those are the coolest finishes I think I've ever seen. The whole guitar just reeks of cool. Awesome job.
  10. Tom Pettingill
    Tom Pettingill Tele-Holic
    California
    Coming together great!
  11. Bentley
    Bentley Friend of Leo's
    Kelowna B.C, Canada
    Making a neck to match a top i've already made.
  12. Mightyaxeman
    Pennsylvania
    Thanks Tom. Haven't seen any Pettingills in a while. Are you working on anything?
  13. Tom Pettingill
    California
    Yea, I've got a couple cool projects going. Here is a cocobolo rosewood and birdseye maple P6 I'm working on.
  14. Glen Smith
    Glen Smith RIP
    Wow Tom, that looks great!
  15. Mightyaxeman
    Pennsylvania
    Wow. Incredible! Is that pick guard material your using for fret markers?
  16. jkingma
    45°54'36.6"N 79°59'11.5"W
    Admin Post
    This...
  17. R. Stratenstein
    Loganville, Ga.
    John, it looks like you've become quite the furni-toor builder here lately!
  18. Jupiter
    Jupiter Telefied Ad Free Member
    Osaka, Japan
    Got the Unknown Jupiter on the bench. Re-doing the neck profile (taking some of the shoulder off), tuning up the headstock outline (some warbles that didn't show until the T-O went on), etc. I want to do something either with the heel or the pocket to get the saddles lower without having to use a shim, so I'm deciding whether to sand the heel or deepen the pocket a couple mm. Also, in the weeks since the Build Challenge, the clearcoat has continued to off-gas and shrink, and now it has a pebbly surface, so I'm going to sand it flat again. That should be fun. :neutral:
    I'm never going to try to build a guitar in 8 weeks again....
  19. jamorudd
    jamorudd Tele-Afflicted
    Oklahoma City, OK
    The beginnings of my very first (very simple) furniture project, an end table to go by the couch. It's big leaf maple with a live edge on each side.
    Also picked up some maple with a bit of Birdseye figuring that I cut up into three neck blanks:
    And I'm looking to be joining the chestnut club pretty soon:
  20. Model T
    Model T Tele-Holic
    NY
    Still having fun with the honing guide.
    I decided that I don't want to make stuff anymore. I just want to sharpen plane irons and do this all day. Or at least until I run out of board.
    See-through wood.
