JohnnyThul
Finalized the pickup routings, after doweling the first holes I made for the bridge, just using the stewmac calculator....always measure yourself and trust noone, then measure two times more.
I then drilled the holes again, after I checked intonation with two strings temporarily attached on a wooden block. And I drilled them through the whole body to try the Ruokangas approach for fitting a non adjustable wraparound bridge.
Everything fits so far.
Now I need to think about the Potis and switches. basically I want a Les Paul switching with a 3 way toggle and the option of switching the singlecoil in and out. And I want to split the neck Humbucker.
So, I either will need a toggle and 2 mini switches, or a toggle and 2 blend pots, I think.
In the latter case I would only use a master volume and no tone control.
