What's on your workbench today?
crazydave911
East Tennessee
Now the green of my shop 😁
crazydave911
East Tennessee
Some things can move along, switches for the Birch/etc,dye for the Yamaha and bottle squash seeds for uh, squash (banjo) 🤣🤣🤣🤣
crazydave911
East Tennessee
Supposedly banjo/Martin gourds. Hope to grow a couple for a skinhead banjo. Nylon strings and pegs and quite light. My 27" is more like a Gibson banjo weight wise, not really bad but could be better
guitarbuilder
mountainhick
Rocky Mountains
Figured I'd share a little repair project on a Squier VM precision neck.
I bought the bass at a steal, but then, with this problem, turns out not so much a steal! Glad I have the time and ability to make a project out of it.
duh, didn't check whether the truss rod nut moved. Neck had some forward bow, and turned out the truss rod nut was tightened to the point of no return. So after days using some penetrating oil and finally reversing the tip in my soldering iron so the blunt end provided more heat to the nut, it cracked loose. So typically when over tightened like this, there is crushed wood behind the washer. Often people just add washers, but there's another potential problem. This neck had an ebonol phenolic plastic fretless fingerboard. Doesn;t sound like a great plan to me, wood moves with humidity, phenolic doesn't so there will be differential movement which will bow the neck. After some deliberation I decided to remove the fingerboard. With the bow, a straight jig for a router would not work, as it would level across the bow, removing the fingerboard at the ends, but would leave the material in the moddle of the neck. So I figured I'd try freehand on a stationary belt sander. Worked a treat!
partial removal:
Complete removal... dead flat, the wood re-alinged with the tension of the phenolic removed
So then to reinforce at the truss rod nut... I chiseled out the channel and was unable to remove the washer, so attempted to remove the truss rod by opening a channel in the heel below the anchor. Didn't go well, when I was drilling out the anchor plug, some of the wood cracked away. Luckily I can still fix it.
-I pulled out the truss rod,
-routed out the heel of the neck so I can glue in a repair plug after the truss repair. Also will glue in a plug for the anchor hole. You can see that once plugged there will be very little visual impact, only the glue line at the heel end. The fingerboard will cover that side:
-redrilled a new anchor hole 1/2" further up the neck
-At the nut end I drilled about 1/2" deeper into the truss rod channel being careful to not drill through the skunk stripe to allow for a harder wood sleeve to be epoxied in as reinforcement. I only had a 1/2" shank drill extension, and 3/8" shank bit, so jammed strips of aluminum flashing into the extension socket, and used a piece of flashing taped to the peghead as a shield:
-Turned said wood sleeve on my mini metal lathe:
-Am working with acetone to wick out the penetrating oil that soaked into the wood, so epoxy will stick
-Will use JB weld wood hardener to toughen the sleeve.
-welded a new anchor to the truss rod. I turned the end of this rod, then mostly parted it, drilled a hole and opened a channel for the truss rod end to be welded. I did not fully part it, so I could square the truss rod to the anchor with the rod in a vise, and attach the welding clamp electrode:
Looks like I need another post for more pics...
mountainhick
Rocky Mountains
Here's everything layed out in the new location. anchor welded on and weld ground flat:
I should receive the wood hardener today, and will post again when I re-assemble everything. Then time to make the fingerboard. Instead of more expense for a quality ebony board for fretless, I'll just use wood I have on hand and make it fretted. SS frets are all of $13
Medeltids
California
partial removal:
Bass guitar version of open heart surgery...or perhaps perhaps a kidney transplant? Nice work!
bullfrogblues
Southeast Florida
I will be watching you on this as I am about to start a double cut myself.
Thank you! this will be #2. the first was lots of trial and error, but I think we have everything sorted. 2º neck pocket angle to compensate for the adjustable stoptail was the hardest for me. And bolt on instead of set neck. Here's the first one.
stormsedge
Gold Supporter
E. Tennessee, USA
I am signing off to mod my Monoprice 15w...well, a little anyway. Yesterday, I acquired a used Celestion G12H 30w speaker to replace the OEM Seventy80...and I'll probably roll the preamp tubes because I can.
Then, I may roll tubes in my 5w as well. Who knows what I may find?
telemnemonics
Fellow TDPRI member I_make_my_own came over to help me get the foam insulation board down in the shop building project in final preparation for the floor pour that's happening bright and early Monday morning. I really appreciated his help for sure!
I build or used to build houses n stuff but never saw this foam board under poured concrete?
How thick will the slab be?
Rebar in the pour?
Why the insulation, keep feet warmer?
Design stipulated by the garage builder?
Im extra curious because having sold my garage to my neighbor to save my house, I have a slim chance of staying but need a new garage. The one I sold is a trad build on a slab, and I know stuff like pole barn builds can be cheaper.
Site work and the slab is a big $$ number as is wood possibly vs synthetics or metal exterior.
Funny Im actually thinking of buying a race team type car carrier to move garage stuff into for now, building code does not tell me I have to park it 15' from property lines and if I hafta move it has wheels.
Curious what it ends up costing too.
