What would you do?
Discussion in 'The BASS Place' started by Frontman, Nov 18, 2019.
  1. Frontman
    Frontman Tele-Holic
    Tokyo
    So, I have recently been gigging with a bass (I guess pigs can indeed fly), and have been playing a late 70’s Musicman Stingray. Unfortunately, the truss rod in the neck is broken, and is not an easy fix.
    I straightened the neck using heat and a jig I put together, and the neck is just about right, but I have to do the heat-and-adjust treatment every year. The only used replacement necks I have found are priced around $1000 or so, and even at this price they are not in great shape, most of them also seem to have broken truss rods. It’s a maple neck, no skunk stripe, so repairing the neck is probably not an option.
    But, I just picked up a beautiful Rosewood neck from a ‘78 Sabre. The neck has the same dimensions, and can be fitted easily, but the Sabre has a three screw neck plate instead of the six screw plate on the Stingray. It seems a shame to either drill out a nice Sabre neck, or an early Stingray body, and I am tempted to sell the Sabre neck and just “adjust” the Stingray’s neck as I have been doing.
    Any advice?
  2. RodeoTex
    RodeoTex Doctor of Teleocity
    Nueces Strip
    Seems like someone could scratch-build you a neck for a lot less than $1000. Just thinking out loud here.
  3. Fretting out
    Land of Mary
    If anything I’d drill into the neck before the body , will be a less visible mod
    And it’s always reversible especially if you decide to sell the Sabre neck
    If you bought the neck for this purpose I’d use it, without a body it’s just a part and a players piece
  4. dogmeat
    dogmeat Tele-Afflicted
    Alaska
    bear in mind I have not seen it, but seems to be a no brainer. fill the neck holes first,
    drill the neck to fit the body. (well... pilot holes). now it plays
    the other option is route the original neck for t-rod repair & stripe it.
    maybe do both...
    Bassman8 and Fretting out like this.
  5. Bassman8
    Bassman8 Tele-Holic Silver Supporter
    Centrally South PA
    Another vote for filling, drilling and using the Sabre neck. Post pics when you are done!
    kodiakblair likes this.
  6. kodiakblair
    kodiakblair Tele-Meister
    Scotland
    Drill the neck and forget about it.
    nojazzhere and Bassman8 like this.
  7. blowtorch
    Wisco
    What would you do?
    Obsessed likes this.
  8. ranjam
    ranjam Tele-Holic
    Keep in mind the the rod snapped for a reason; likely the neck has a serious upbow. Me being me, and having nothing to lose; I'd try and remove the fingerboard and repair the truss rod while I plane the neck with a slight backbow. This assume it is snapped near the first fret, and not the spoke end. I've even gone more insane, and cut through the 3rd fret, and just removed the first three frets with the fingerboard. If you can remove the peened barrel nut, you should be OK. A new rod, if needed, can be threaded and installed. Or, you might lose less than 1/2" of the original rod.
    As I say, ya' got nothing to lose. If worse comes to worse, China will sell you a 5-string Stingray neck for $65. ;)
  9. Dismalhead
    Antelope, California
    I understand your consternation because we're talking a really nice bass and neck here, but I agree with drilling the neck and leaving the body intact. I've plugged and redrilled a few necks, and IMO it's not that big of a deal. It certainly doesn't affect the playability or quality of the guitar. I wouldn't reject a guitar I was thinking of buying because of it.
  10. brookdalebill
    Austin, Tx
    I’d just mount the neck you have to it, any rock on.
    Times a waistin’!
    Bassman8 likes this.
  11. KCKC
    KCKC Tele-Afflicted
    Hingham, MA
    In the words of Sarah Palin...
    Drill baby, drill!
    Drill the neck
    KC
  12. Obsessed
    Obsessed Telefied Silver Supporter
    Montana
    Yup, drill the neck if that is a viable option.
