Rufer
If you really want the grain to pop you can use a stainless wire brush before sanding. Then Golden Oak Danish Oil.
Thanks to you both! I will see what damage I can avoid with a wire brush.Exactly what I was going to suggest. I was thinking a soft-brass wire brush, then sand with sandpaper over a folded up towel rather than a sanding block. Definitely test a scrap to see if results meet the target.
Thank you for clarifying. I get it now. Big thanks for all of pictures and explanations too. Very helpful!I actually can't remember if I really applied a sealer, might have just been the clear.
In any case, what I meant was: to get the look, it has to be a thin finish. Any paint will fill the open grain areas to some degree. The more coats you apply the less you will get the right effect. And with a satin finish you can't sand it -you add matting agent (I think it's called) to the clear when u spray. So if u stuff the spray job up, you can't sand it back and respray since you will be filling the grain. So if you sand back, you'll have to REALLY sand back and start all over again.
Here's a pic of the body doing the
