Guitartom_ca
I bought a fender 65 deluxe reverb reissue amp a while ago. a friend said that i should upgrade to higher quality filter caps, should i do this? how will it affect the tone? thanks.
How long ago is "a while ago"? If your RI is still pretty new, the filter caps probably don't need replacing. If they do, you'll know because you hear a hum you can't get rid of.
Higher quality in what respect? You might be able to replace them with caps with a lower tolerance (say, 5% or 2% tolerance instead of 10%) and make it more exactly the way it was intended to sound. But if it sounds the way it should now, the ones you have may have values that are actually only 5% or 2% off "perfect" already. It's an expensive way to find out just how close your particular amp is to the intended specs.
Now, if he meant you CAN change them to other VALUES (not tolerances), certainly you can, and thereby change the character of your amp. Here's a thread by sme guys who really know their stuff about this. It's about a different amp design, but the concepts apply:
http://www.thegearpage.net/board/archive/index.php/t-1126397.html
If your RI is true to the original design, these guys talk about such an upgrade because better caps back in '65 were much larger and expensive than now. But if, as they say, Fender has put better caps in the RI than in the original, this "upgrade" has already been done. Some here may know about the RI and its caps. If not, try the Fender forums at fender.com. But again, it may change the character of the amp. If it's historically accurate and has the caps the original did, the upgrade may result in an amp that doesn't sound like the '65 at all.
Then again he may have just been talking about something he knows can be done in order to sound knowledgeable. Ask him what he meant by "better quality" and why he thinks your particular amp needs it. Perhaps he'll have some specific reasons with clear explanations. Even so, I'd get others' opinions that are familiar with that amp.
Caps with lower esr or higher ripple current if you were looking at the data sheet would be what you were looking for or you can jut buy some F&t caps and call it a day. It will make the notes sound clearer, sweeter, more defined. You will be able to hear a lot more of the transients. I know muchxs just said your wallet but ship him a gift box axial Illinois or jamicon caps see if he starts using them building amps then puts his name on it.
Replacing the fresh but relatively nondescript caps in a recent DRRI with more expensive caps will have a single noticeable effect... your wallet will be lighter.
That's no excuse for limping along with the originals in a 40+ y.o. original Fender.
If you DRRI sounds fine and no hum then leave it alone... you could always look under the dog house and inspect the caps. If they look anything like what I found in my 10 year old Fender Vibroverb then get rid of them!
Those IC caps don't really last, but if they're in good shape no need to replace them.
I went with F&T caps and the amp just sounds "healthier". Everything sounds cleaner, more tight bass and clean bright tone.
For what my opinion is worth.....the above about sums up all there is to say on the topic.Replacing the fresh but relatively nondescript caps in a recent DRRI with more expensive caps will have a single noticeable effect... your wallet will be lighter.
