What voltage does a Vibro Champ's 12ax7 like to see ...
Discussion in 'Amp Tech Center' started by trouserpress, May 6, 2021.
  1. trouserpress
    trouserpress Tele-Holic
    Leipzig
    .. for example to help a good sounding amp sound better?
    Someone on another forum said there shouldn’t be more than 200V at V1. At my Vibro Champ’s V1 I read 220V (spec=205V) at pin 1 and 215 (spec=200V).
    Is it worth struggling with the dropping resistors? Lately I brought the bias resistor from 570R (->13,5 Watts) down to 470R (stock -> 14,3 Watts). Soundwise that change wasn’t altogether good: Seems I traded „fenderishness for mellowishness“ (oh dear - forgive me).
    Any thoughts?
  2. jimgchord
    jimgchord Tele-Afflicted
    victor,ny
    20 volts wont make much difference. I prefer to change the cathode and load resistors if a v1 bias change is needed rather than mess with the dropping resistors.plot the load lines to see where you need to go.
    trouserpress likes this.
  3. trouserpress
    Leipzig
    Thanks Jim, that's about where I was gravitating to. I think about it some more and will probably swap the cathode resistor and the plate load resistors for slightly bigger ones.
