Jewellworks
ive heard electrolytic's arnt good for tone section. there are so many cap types (film, silver mica, ceramic, poly) what works best for audio filtering?
In amps there are numerous and entirely common uses of ungrounded tone caps in line with the signal.In a passive tone circuit in a guitar, any signal that goes through the cap goes to ground,
The problems with "What's new" feeds.before the guitar guys take over the thread completely?![]()
Fender, or any mfgr, doesn't use electrolytics in bass or mid caps. They used foil caps or metalized film. Most amps now use metalized film (smaller, cheaper) for those positions and ceramic or silver/mica for the treble and high bypass positions.Hmm, electrolytics? Maybe "tone section" is ambiguous. When you said silver mica etc, I thought you meant little bright and treble caps, but maybe you mean big caps like Fender's 'bass' and 'mid' caps, where electrolytics are used most commonly? Can you clarify -- before the guitar guys take over the thread completely?![]()
Polypropylene is harder to spell than polyester, so it must be better. QED....First, a question. I've read someone smart (no longer recall who) saying that for very small caps on pots, polypropylene was objectively better than polyester. Sadly, they didn't explain why they said that. Anyone know more?
I have seen it on a couple of Dumble schematics, notably for coupling caps, but also in the tone stack. But who the heck knows if those schematics were accurate. But yes, the technique is often seen in audio power supplies.I see this in power supplies where a "fast" cap foil/film is paralleling an electrolytic, or in audiophile amps, using sometimes three caps in parallel of decreasing value. Say a 10uF electrolytic, a 1uF foil/film, and a 10nF polystyrene.
Some builders use Polyamorous caps, which is where they parallel two or more caps of different types to makeup the desired capacitance value, in order to add some spice and swing to the amp.![]()
