What to build with a broken JCM2000 DSL100
Discussion in 'Shock Brother's DIY Amps' started by nasdak, Jan 20, 2019.
  1. nasdak
    nasdak Tele-Meister
    france
    Hello folks
    currently have a JCM2000 DSL100 on the bench, it has the faulty main pcb, everything becomes conductive, there's no way to save it appart fitting a new board, not worth the expense i think.
    I wonder if someone already used one for a new build ? Are the trannys ok for say a 1959 or a 2203 ?
  2. clintj
    clintj Friend of Leo's
    Idaho
    What's the HT winding like on those, like 700V aka 350V each half? Probably net something approaching 500V of B+?
    Yeah, that set should be a fair match for a later 2203 (the earlier ones and JMPs ran lower IIRC). Question is what to do with any extra holes in the chassis, but a custom set of faceplates should help with that.
    Sent from my Pixel 2 using Tapatalk
    dunner84 likes this.
  3. dunner84
    dunner84 Tele-Meister
    Victoria, bc
    +1 for 2203 and a new faceplate.
  4. Dacious
    Dacious Poster Extraordinaire
    Godzone
    The boards were available as a warranty replacement, even out of original 1 year purchase warranty. Marshall acknowledged there was an ongoing issue with DSL and some TSL models due to the material used becoming conductive.
    It might be worth contacting them and asking - they may honour it and replace the part
  5. nasdak
    nasdak Tele-Meister
    france
    I contacted them with no luck :(
    Well, it's gonna be a base for a 2204 jcm800.
    50w so i need a new OT!
    Envoyé de mon Redmi 4X en utilisant Tapatalk
  6. Lynxtrap
    Lynxtrap Tele-Holic
    EU
    Why not just keep the output stage as it is and change the rest of the circuit to 2204 and save the cost of an OT? Even if you would want to run it at full output volume, the difference between 50W and 100W isn't enormous. Both are enough to blow your ears out.
    jtcnj likes this.
