What the heck kind of tool do I need for my truss rod?
Discussion in 'Tele-Technical' started by Dbsoundman, Jun 10, 2021 at 2:31 PM.
  1. Dbsoundman
    Dbsoundman TDPRI Member
    Maumee OH
    This is a really weird one, partscaster I picked up on Reverb. The action is really high, so I went to adjust the truss rod...but no allen wrenches "bite". I tried taking pictures of the hole, it's not easy but it doesn't look like it has...anything in there? Tried a phillips screwdriver, nothing either.
    Help?
    21-06-10 14-23-34 3444.jpg 21-06-10 14-23-15 3442.jpg 21-06-10 14-23-24 3443.jpg 21-06-10 14-23-11 3441.jpg
  2. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    New one to me. Could the nut be gone? Is there another adjustment point on the other end of the rod?
  3. esseff
    esseff Tele-Afflicted
    East Midlands, UK
    A (plastic) plug covering the truss rod adjuster maybe?
  4. Dbsoundman
    Maumee OH
    I would have to remove the neck to figure that out right?
  5. Boreas
    If you can't see anything by the pickguard, yes. But I wouldn't bother yet - likely someone here is more familiar than myself. Do you know what brand of neck it is? It doesn't seem to have a Fender neck plug.
  6. magicfingers99
    magicfingers99 Friend of Leo's
    atlanta
    acetylene
  7. Dbsoundman
    Maumee OH
    I'm guessing it's a no-name company neck, but I do like the feel of it!
    Boreas likes this.
  8. wabashslim
    wabashslim Friend of Leo's
    Sonorous Desert
    I'd ask the seller...
  9. magicfingers99
    atlanta
    take the 2 string off or out of the way that are closest to the truss rod adjustment.
    and then take a picture. your camera/phone is autofocusing on the strings.
    it could be an octupus in there and I can't see it.
    worst case if you cant figure it out, you can superglue a tool in there. adjust it and then use acetone to break the superglue bond. its like welding a rod onto a broken automotive nut, a technique used since the invention of the stripped bolt.
  10. Boreas
    You shouldn't adjust action with the truss rod. You only adjust relief with it. Unless you can see a huge up-bow in the neck, the truss rod isn't your answer. You may need to adjust your bridge or possibly add a shim to the neck. Check your neck with a straightedge, and unless there is a significant up-bow, leave well enough alone for now.
    gerhard_k, Racer5 and magicfingers99 like this.
  11. Dbsoundman
    Maumee OH
    You're right, I'm new to making my own adjustments, just remembered to check and sure enough the relief is right on.
    I also messaged the seller (duh) to find out what he used to adjust teh truss rod in case that ever becomes a problem.
    I'll fiddle with adjusting the saddles later on.
    Boreas likes this.
  12. magicfingers99
    atlanta
    this is true. I learnt it the hard way. but it does help one to learn how a guitar really works. also its a great excuse to buy more tools, I've got 2 notched fret rulers now
    I swear by them.
    upload_2021-6-10_15-7-30.jpeg they are quite cheap these days.
    Boreas likes this.
  13. Dbsoundman
    Maumee OH
    Seller replied, he did use an allen wrench but he's not sure what size. I think maybe I just need an "in-between" size, my allen wrench sets are not very big so I don't have every increment out there.
  14. hnryclay
    hnryclay Tele-Meister
    Virginia
    Is it metric?
    telemnemonics likes this.
  15. LutherBurger
    LutherBurger Poster Extraordinaire
    NYC
    I have a no-name neck whose truss rod nut looks like yours. Mine takes a 4mm hex wrench, and it's quite deep in the hole, well past the top of that silver-colored sleeve. A hex wrench that's too short at the business end won't reach it.
    telemnemonics and Boreas like this.
  16. Laren
    Laren Tele-Meister
    West Somerset
    More than Likely 4mm or 3/16. If it' 3/16 be carful as the 4mm will fit but it's slightly smaller and you may strip the recess.
  17. netgear69
    netgear69 Tele-Afflicted
    england
    Maybe it has just be stripped out therefore it is now toast
  18. Cosmic Cowboy
    Cosmic Cowboy Tele-Holic
    New Mexico
  19. Freeman Keller
    You tried both metric and imperial allen wrenches I assume. Also, you do know that the truss rod is not how you adjust action.
  20. Diytelecaster
    Diytelecaster Tele-Meister
    5mm Allen key I reckon. My Squier is a 5mm but need a long series ball end to reach it.
