SixStringSlinger
I have a Dunlop volume pedal that I also use as an expression pedal for two different other pedals. I use a TRS balanced cable, which as I understand is necessary to use one cable between the expression and the expresso.
I want to try using a splitter (and the appropriate extra cables) to hook up the expression pedal to both other pedals simultaneously (rather than have to switch one cable back and forth). I doubt I'll use both other pedals at once so I don't think that will be an issue.
Will any 1/4" splitter (and the same type of cables) do, per does the splitter need to be as special as the cable?
