What size knob
Discussion in 'Tele-Technical' started by ieatlions, Nov 12, 2019.
  1. ieatlions
    ieatlions Tele-Meister
    Wales, UK
    Newbie question here.
    Ordering parts for a build. Not 100% on which Volume/Tone knobs I need to order. These are the pots, so I’m assuming this is a ‘split shaft’. Should the knobs be 6mm in as well or 6.2mm?
    Thanks in advance
  2. moosie
    Western Connecticut
    Bourns pots have 18 splines. Knobs come with 18 and 24. 24 is mostly US stuff like CTS.
  3. Vizcaster
    Glen Head, NY
    Just for those listening in, those are long shaft pots for a solid top where you rout out the control cavity from the back (Les Paul style). Sounds like an interesting project.
  4. sparkymike
    sparkymike TDPRI Member
    If the new build is for a repro then I would go for solid shaft 1/4" diameter pots and buy knobs to suit.
    Loads of choices on a site such as Warmouth
    Mike.
  5. ieatlions
    Wales, UK
    Thanks for the replies. I’ve found the appropriate knobs it seems.
