What size are the 2 resistors
Discussion in 'Shock Brother's DIY Amps' started by Cam, Feb 10, 2009.
  1. Cam
    Cam Tele-Afflicted
    Kanata
    in this pic of power caps?
    http://www.tdpri.com/telephoto/showphoto.php/photo/13658/cat/500/ppuser/166
    Incidentally those are the caps that were in bandmastered deluxe reverb. I left the orange but changed the silver. I will probably change the orange as they are over 10 yrs old I assume. I assume I should probably cput in new resistors. I stand to be helped and corrected by the learned. The learning continues......
    Thanks
  2. Schwalbe
    Schwalbe TDPRI Member
    MPLS MN
    They look like one watt carbon composition. You can use metal oxide or metal film to replace them. Modern metal oxide/metal film 1 W are smaller.
  3. milocj
    Michigan
    It looks like a 4.7K (yellow, purple, red) and a 1K (brown, black, red) if those are the actual colors I'm seeing in your picture. The schematic for a blackface Bandmaster shows the same values, both 1 watt ratings.
  4. Cam
    Cam Tele-Afflicted
    Kanata
    actual colours....
    Yep! Thanks
    silver red purple yellow
    and
    silver red black brown
  5. Papa Joe
    Papa Joe Friend of Leo's
    Swanton Ohio
    Check the voltages,if they are near correct leave 'em alone..Those resisters seldom need replacing..I wouldn't change the caps either unless they look or sound bad..I know the techs all say 10 years life span but I've seen 20 years on some and still good..
    BTW,whatever you do,be sure to discharge those things before you do any thing else..They bite big time,and you might not be lucky enough to get a second chance.I goofed one time and got hit hard enough to knock my upper dentures out of my mouth..Lesson learned.....PJ....
  6. Cam
    Cam Tele-Afflicted
    Kanata
    Thanks PJ. Draining the juice was the first thing I learned to do before adventuring on the tweak road. Being the paranoid guy, I watch it drop through my meter, so I don't drop.
