What Pedal Board?
Discussion in 'The Stomp Box' started by jklotz, May 5, 2018.
  1. jklotz
    jklotz Tele-Afflicted
    Atlanta, GA
    So I'm in the process of putting together another board. I want a slimed down, lightweight, "bare bones" board for some of the smaller shows and rehearsals. I've got a pretty good handle of what to put on it, the question is what to put it on. I've only used pedaltrain before. They seem to make good stuff. What other boards do you guys like?
    Also, what power supplies do you guys like that will fit a smaller board? I was looking at those one spot pro CS6, which are supposed to be low profile, so they can mount under smaller boards. Any other solutions I should be aware of?
  2. WetBandit
    WetBandit Friend of Leo's
    Somewhere
    I'm a fan of both pedaltrain and the MXR DC Brick
  3. DaveKS
    DaveKS Friend of Leo's
    KS
    Define smaller board? 3 pedals? 7?
  4. LooseJack
    LooseJack Tele-Meister
    transit lounge
    cioks PS fits under PT nano and mini
  5. bigben55
    bigben55 Friend of Leo's
    Cincinnati, OH
    For a @5 pedal board, this is the BEST solution. Cioks DC5 and PT Nano+.
  6. blackjaw
    blackjaw Tele-Meister
    RI
    I have a CS6 and it fits under a Nano+ and Metro 20...I swap it back and forth depending on the size of the board I am playing.
    CS6 is a great power supply and I actually like it better than the Cioks DC5 or Adam because of the two 500ma ports and the ability to do 12/18v on every port (great for running a compressor at 18v)
    LAGinz likes this.
  7. jklotz
    Atlanta, GA
    I'm going to be running a Helix HX (The effects only Helix) with an expression pedal, and I'd like a little extra room for experimenting with other pedals in the loop. But at the same time I'd like to keep it compact and light. The HX pulls close to 1000 ma, and the one spot guys have a video showing how the CS6 will power it, so I am most likely going that route. (Otherwise, I'm stuck with a power cable that has the big block in the middle, which kind of messes up the whole clean and compact part of the equation.)
  8. Beachbum
    Beachbum Friend of Leo's
    Sand Land
    I put this one together using an SKB board and a case from Rondo. I ran the wires under the board and screwed the board to the case from the bottom. Everything fit perfectly with just enough room for eight pedals and the power strip. The top is removable.
  9. DaveKS
    KS
    With the 8x11 footprint of HX+exp+Extra pedals the pedaltrain metro 24 is only one that makes sense to me. Being as HX already has angled front plate and also the exp pedal I wouldn't want a angled board.
  10. Kayle McGuire
    Kayle McGuire Tele-Meister
    I’d recommend a Pedaltrain Nano+ or Metro of some kind. If you like it flat. If you want it elevated, try a Pedaltrain Classic Jr. or Classic 1.
  11. LooseJack
    transit lounge
    Dang, the CS6 looks great. How long has that been out for?
    It's not 12/18 on every port though is it? It looks like:
    2x9
    2x9/12
    2x9/18
    blackjaw likes this.
  12. blackjaw
    RI
    You are correct, the two 500ma plugs do not have a voltage option and are standard 9v only.
  13. jklotz
    Atlanta, GA
    Yea, I went with that. Ordered yesterday. This, in my case, is what sold me:
  14. uriah1
    Around
    Small I like my BCB60.
