What neck humbucker do you prefer?
Fender_Player90
Maryland
Other than a Full size PAF style humbucker, which humbucker do you prefer in the neck on your Tele? Im debating myself. Dont want a PAF because I want something more "Fendery" but thicker than the stock neck pickup. I wanted a Fender Wide Range but that design to get an original sounding one is elusive.
Then I thought a Neck Filtertron might be a good jangly alternative. Or a Firebird pickup or Mini Humbucker? Also an option could be is run a hotter wound PAF and wire it in parallel.
What works good and what dosent?
Jakedog
The North Coast
For a full sized bucker that’s bright and dynamic, maybe try a DiMarzio EJ Custom or Humbucker From Hell. The name on the latter is very deceiving.
ReverendRevolver
Ohio (Nerk)
Tv jones Setzer signature goes well with a Bootstrap Pretzel at the bridge, not all trons are straight jangle, there's 3ish flavors.
Obviously not a tele, but IF you could figure out a way to balance the volumes and rig up a way to switch between the 3 modes, a Duncan P-Rails gives a p95, a hot rail, and a hot bucker that fits in a paf sized hole.
I think trons, p90s, firebird pickups, and minis all do different things when paired with a tele bridge pickup, and all lend to a fantastic versatile combination.
But.
If you're after sounds from a tele bridge pickup or a humbucker and don't specifically need as much of the 2 at once, there are plenty of paf sized humbuckers that will work great. As Jakedog suggested, that dimarzio or the 2 blade bucker would get you sounds like you're describing. You seem to not want muddy at all in your setup, are you after an actual double coil, or just "over it" with the lack of distinction from typical tele neck pickups? There are hotter, thicker, more defined, and just generally more useful sounding 1 coil options in every size pickup imaginable as well. Most interesting sounding one that fits in a typical tele neck hole was Rose pickups Morticia, but I'm told they're no longer in business. Plenty of companies do something similar though.
MAS Tequila
Southeast Florida
But.
SD Triple Shots, they are mounting rings with switching built in to control the P Rails.
MAS Tequila
Southeast Florida
I went big, I put a full size Seymour Duncan JB Gibson spaced bridge humbucker in the neck.
It's awesome, clean it will give you those creamy bucker tones and split is where it shines.
When you're done being clean, just twist the guitar's volume knob and she'll spank the front of that amp giving you some great overdrive without pedals.
And then take pedals like a pro.
ERik77
Fresno
I do love a filtertron. I have an SD Jazz in the neck of one tele and it works pretty good.
Maguchi
Lalaland
Fender CuNiFe WRHB.
Fender CuNiFe WRHB.
jim232777
Charlotte, NC USA
I have a Fralin Unbucker that has amazing clarity for something in the PAF family, so I would be browsing other options from Lilndy. He has humburker-sized things that run the gamut from "Fender-y" to "thick single coil" to P90 sounds I'm sure you can avoid mud with one of his.
Gris
Cumming GA
I have mini-HB (Klein), firebird (Lollar) & filtertron (TV) and P90 (Mojo) in the necks of Teles. They are all great but different. The FB has the most ‘bite.’ The P90 has the most ‘punch.’ The tron has great warmth & crunch. The mini is the ‘jazziest’ and most ‘3D.’ YMMV
TX_Slinger
The Sticks, TX
Im enjoying the Seymour Duncan Psyclone neck pu. Does all the things but noiseless. Filtertron-like when clean and slightly overdriven but gets PAF with a lot of gain.
