what machine heads fit this fender neck
Discussion in 'Telecaster Discussion Forum' started by ben smith, Oct 20, 2019.
  1. ben smith
    ben smith Tele-Afflicted
    london
    after buying substandard necks from substandard companies recently for my next build only the best will do. this is the specs for the neck, are they kluson holes? I just can't tell the spacing looks weird. thanks
    Fender 1951 Telecaster Neck MN, U-Shape/9.5" Radius preview.jpg preview (1).jpg
  2. boris bubbanov
    New Orleans, LA + in the
    Almost all MIM necks for "vintage" tuners are to be matched with Ping splits, except for a few with Gotoh locking vintage machines. This means the Gold Standard Gotoh split (Allparts # TK 0880) would require conversion bushes and some enlargement of the hole.
    However, I THINK either or both of the WD and Wilkinson brand "split" machines can work. We need someone who uses those to confirm this, though.
    The one MIM neck that uses conventional Gotoh splits (like USA AVs do) is the Jimmie Vaughan. It stands alone.
    I used to take Ping splits off of MIM guitars and replace them with Gotoh splits. But these days, nobody does that anymore. The Ping splits have improved that much.
    ben smith likes this.
  3. monkeybanana
    monkeybanana Tele-Holic
    mmhmm
    I don't have the same exact neck but my Mexican 60s neck takes "vintage" style tuners. I would shoot Fender an email if you don't have a way to measure. I've had good experience with the customer service.
  4. ben smith
    london
    thanks the for reply
    boris bubbanov likes this.
  5. ben smith
    london
  6. ben smith
    london
    these look like standard kluson style tuners to me? so these would work?
    bumnote likes this.
  7. merseymale
    merseymale Tele-Meister
    LIVERPOOL
    it does seem like it’s made for a STRIP of vintage/non-sealed ‘heads
  8. Chunkocaster
    In space with Ziggy
    The Mexican Classic series necks can take Classic vibe, Kluson, Fender and Gotoh vintage style tuners.
    They are all the same size and screw spacing. The bushings might vary although I've never had any trouble interchanging them all on Allparts, mim Classic series and Classic Vibe necks.
    I stick with Kluson stamped (WD) tuners for 60's or the Classic vibe non stamped tuners for 50's both in nickel.
    Make sure you see a pic of the split shaft if ordering online, Wilkinson and a few others offer posts with holes in the side like acoustic tuners. They suck imo.
  9. ben smith
    london
    thanks man, the only thing throwing me off about it is the last hole on the top of the headstock looks really far up if you know what i mean? the distance between all the holes just looks different, like they should all be centered more. a beautiful high quality white blonde ash body is going on this build too s-l1600.jpg
    boris bubbanov and Chunkocaster like this.
  10. Chunkocaster
    In space with Ziggy
    It looks good to me, the screw should sit about 14-15 mm from the centre of the last post. The first screw is positioned about 9-10mm from the centre of the first post on Vintage, Kluson style tuners. Its a hard thing to measure precisely when the tuners are fitted but I just measured mine with a tape measure to get the above measurements.
    That body looks nice, should be a cool tele when you get done.
  11. ben smith
    london
    sweet thanks. yeah the body isn't cheap, it's going to have all gold hardware good pickups and a chopped guard, it will be stunning!
    Chunkocaster likes this.
  12. bumnote
    bumnote Tele-Holic Ad Free Member
    Northern Virginia
    Kluson's will work. I bought an MIM lacquered Strat neck, they're cut for vintage style tuners. Kluson, Ping...anything with vintage specs will work.
  13. ben smith
    london
    do you have any idea what size string tree this will have? i know it's a single round type tree but they come in 5mm or 7mm tall
  14. Rayf_Brogan
    Rayf_Brogan Tele-Meister
    I have a classic 50s strat neck and my vintage style Kluson line up perfectly, however the peg hole is 1mm wider than the US necks I've used. The bushings would just fall out when I tip the guitar over. They make conversion bushings that fit the MIM holes perfectly and allow you to use normal Kluson tuners
  15. Chunkocaster
    In space with Ziggy
    I'm not sure on that, I don't have my guitar handy atm but I use the shorter string tree of the two on my necks with 60's style string trees.
  16. jfgesquire
    jfgesquire Friend of Leo's
    Lake View
    baiff, boris bubbanov and ben smith like this.
  17. schmee
    That appears to be for vintage style Klusons.
  18. ben smith
    london
    I am a massive pearloid fan but not sure that would world on the white blonde? i also like chopped guards. but I am thinking 1ply white for sure would look nice, ill try a few. great pick though yum!
  19. ben smith
    london
    so what size bushings would I need? 8 or 10 mm? thanks
  20. jfgesquire
    Lake View
    You'll likely need a conversion bushing so that the skinny vintage post is firmly centered in the larger diameter reamed hole.
    There are many different sizes. The stewmac site can be used for reference. I ended up with some from ebay.
    There are many little differences - you can certainly get exactly what you want if measure twice and know what the dimensions are.
    https://ebay.us/lHcRDQ
    https://www.stewmac.com/Items.aspx?search=Tuner_parts/Tuner_Bushings
