What looper has the best tone?
Discussion in 'The Stomp Box' started by Blackbird86, Oct 15, 2019.
  1. Blackbird86
    Blackbird86 TDPRI Member
    Indiana
    Currently using a 8ish year old digitech jamman, but i notice my guitars sound better plugged directly into the amp than through my jamman then into that same amp. What looper has the best tone?
  2. bftfender
    bftfender Friend of Leo's
    York PA
    have a lil Ditto..spits out what ya put into it
    MrCairo46, joealso, Erdowonge and 2 others like this.
  3. Ripradiant
    Ripradiant Tele-Afflicted
    Alberta Canada
    The one with the best player in front of it!
    MrCairo46 and brookdalebill like this.
  4. BigDaddyLH
    BigDaddyLH Tele Axpert Ad Free Member
    Kelowna, BC, Canuckistan
    That explains why mine sucks :(
  5. jddub440
    jddub440 Tele-Holic
    Tacoma
    I bet those new Chase Bliss Audio loopers sound pretty sweet....the Mood and the Blooper.
    El Tele Lobo likes this.
  6. Obsessed
    Montana
    Looping is a many splendered thing, but for best results there are a few rules to adhere to.
    First off, you need to loop into a crystal clean amp, because you are layering over each loop. If you add your dirt before the looper, only that loop will have the dirt. Otherwise everything gets progressively dirtier.
    Also, your amp typically plays one guitar, but after you start looping, your amp is playing multiple guitars.
    I could go on, but wonder if these are issues for you to consider.
    sirbergersworth likes this.
  7. Verne Bunsen
    Verne Bunsen Tele-Afflicted
    Sonoran Desert
    My Boomerang III doesn’t exhibit any noticeable tone degradation.
    Texicaster and FenderLover like this.
  8. schmee
    My Ditto's don't seem to change the tone a bit.
    But I think you need find a Blackface one with roasted maple and RCA Blackplates!:eek:
    Erdowonge and Wildcard_35 like this.
  9. brookdalebill
    Austin, Tx
    I’m happy with my EH Canyon.
  10. Ripradiant
    Alberta Canada
    But, IMHO it's the tool that really helps!
  11. Lies&Distortion
    Lies&Distortion Tele-Afflicted
    SE Michigan
    My sample size of one tells me the Boomerang III has good tone for my ears using my guitar, amp and pedals.
    I expect you will have similar answers from users of other loopers. Lots of variables.
    Texicaster likes this.
  12. beninma
    beninma Friend of Leo's
    Massachusetts
    I’d just check if you have a true bypass tone suck situation. If you’re used to plugging straight into the amp you might be noticing some attenuation of higher frequencies due to more cable plus the pedal when it’s not in use.
    If the pedal is currently playing a loop this is not a factor.
  13. Texicaster
    Texicaster Tele-Holic
    Arizona
    Another for Boomerang III
    Records in 48KHz or 24KHz, both use 20 bit samples; through signal is always 48KHz / 24 bits.
  14. jimash
    jimash Friend of Leo's
    NJ
    I have a Boss RC50, and my experience is it likes to be hooked up to a mixer better than an amp.
  15. joealso
    joealso Tele-Holic Silver Supporter
    East Haddam, CT
    Ditto on the Ditto
  16. j5jarod777
    j5jarod777 Tele-Meister
    marysville
    Can't go wrong with a Ditto
  17. LowCaster
    LowCaster Tele-Holic
    Paris, France
    I think the OP is talking about the buffer/bypass, not about the tone of the loop.
    The Boss RC3 is on my pedal board, very good too, but as in any boss pedal there is a buffer that is sucking just a little bit of tone even when not in use (IMHO/YMMV... some people want buffers in their pedalboard for a reason). Having more than one or two pedals on the pedalboard, even if they are true bypass, does the same thing, because of the added cable length and connection.
    I believe that any looper would have a buffer, maybe there is one that is really true bypass?
    Anyway, that’s not something you can really hear, it’s something that you feel when you plug back straight to the amp, and when you are playing alone in your basement. If you can hear that in any band playing situation, then there is a problem.
