What is the mod that blew you out of the park?
Discussion in 'Telecaster Discussion Forum' started by 19sixty3, Dec 21, 2020.
  1. lammie200
    lammie200 Friend of Leo's
    San Francisco
    6-way with bypass Rothstein Varitone with tone depth concentric volume and tone pot wiring to fit standard Tele control plate without modifications.
    TequilaCaster and 19sixty3 like this.
  2. beanluc
    beanluc Tele-Holic
    California Bay Area
    "Tone depth"? Does that just mean mixing the Varitone level with a pot instead of hardwiring to the selector switch?
    19sixty3 likes this.
  3. lammie200
    San Francisco
    Yes, you still have a tone knob. The varitone is a selector switch. It is wired similar to page 56 of the PDF. I am not using the Stellartone Tonestyler though. I like the Rothstein varitone better.
    https://stellartone.com/custom-tone-controls-custom-wiring-diagrams/
  4. sdsy1212
    sdsy1212 TDPRI Member
    China
    The killswitch
  5. pinchegil
    pinchegil Tele-Meister Platinum Supporter
    Roxborough Park, CO
    On rosewood necks slightly rounding the edges with an emory board, instead of rolling them with a hard object. I has a different feel and doesn't compress the wood around the frets. Playability is the first mod I make to any guitar
  6. schmee
    schmee Doctor of Teleocity
    Probably the Fender Mid Boost. I've had it in all my Strats for years.... and some other guitars!
    By the time you get 5 way switching and add the mid boost variable to those 5 you have an infinite number of tones without ever stepping on a pedal.
    The mid boost just adds a bit of depth at 1-3, at 4-6 it gets great for slide, above that it's woman-tone.
  7. beanluc
    beanluc Tele-Holic
    California Bay Area
    Oh, I get ya.
    Reading "tone depth" sounded to me like something other than a normal tone control. Like "depth" of the Varitone effect maybe.
  8. Wrighty
    Wrighty Friend of Leo's
    Essex UK
    Great story. The practicalities of being in a band that the audience rarely get to know. There’s a fine line between looking a fool and looking sophisticated and I think you’re just on the right side!
  9. 3-Chord-Genius
    Winchester, VA
    Treble bleed on a Gretsch Electromatic was the most useful mod I've done.
  10. lammie200
    San Francisco
    He does describe it differently, but it seems to work the same way as a conventional tone control IMHO.
  11. Masmus
    Masmus Tele-Holic
    San Jose
    On my 78 Strat, Dimarzio Fat Strat pu's and tone control wired to the bridge pu.
  12. Sconnie
    Sconnie Tele-Afflicted
    CO
    Both pickups on my SG are tapped, and the configuration you described is pure gold! I have a series switch too, putting both on single-coils and in series is really great as well. Not all combinations are worthwhile, but the few extras on a single guitar make a huge difference to me.
    Rock on!
  13. lupowitz
    lupowitz Tele-Afflicted
    Hungary
    EMGs...
    I like that they universally require 25K pots, and are coming with the quick connector system, so I can change them as I please. I have 4 guitars with them and they come and go from one into the other. The most usefull this proved to be with a cheap, but bulky necked Tele knock off, that I constantly play around with. It can be normal tele neck, or strat neck, minihum neck, or full humbucker neck. It mostly is the later, with -wait for it- an 81 in the neck posi. It takes 5 minutes to change them around.
  14. JRapp
    JRapp Tele-Holic
    Phoenix, AZ
    Strat baseplate
    Replacing the necks on my 80s AVRI guitars with Allparts Fats
    Bootstrap pickups
    Installing some washers on the truss rod of my '56 RI Goldtop
    TequilaCaster, 19sixty3 and Chiogtr4x like this.
  15. Chiogtr4x
    Chiogtr4x Doctor of Teleocity
    Manassas Park, VA
    Can you explain what the washers on the truss rod of your Les Paul do thank you
  16. El Tele Lobo
    El Tele Lobo Poster Extraordinaire
    I really like this. Great idea!
    TequilaCaster and 39martind18 like this.
  17. Willy-son
    Willy-son Tele-Meister
    NJ USA
    Seymour Duncan Seth Lover in the neck position.
  18. Minivan Megafun
    Minivan Megafun Tele-Afflicted Gold Supporter
    Manitoba
    Pickups. They really do affect the character of an instrument. They can take a guitar from "meh" to "yeah!"
  19. Minivan Megafun
    Manitoba
    How does the Seth lover compare to the tone of the SD '59 or even the Gibson 57 Classic?
  20. El Tele Lobo
    Changing pickups is probably the most significant mod in terms of blowing me out of the park, as is adding a 4-way switch. Depending on the tele pickups in play and how hot they are, it can give you either a humbucker tone or even a P90 tone. Makes an already versatile guitar infinitely more versatile.
    Reverse control plate really helps with playability, for the stuff I do.
    Some things I was surprised to discover I liked over the years that aren't so much mods as old-school standard designs:
    • Low-output pickups
    • 7.25" radius
    • Small frets
    • Fat necks (U, C and soft V...I like all of them to varying degrees)
    • Body-mounted neck pickups
    • Vintage-style slotted tuners
    • Heel-adjust truss rods
    Modern design upgrades I later learned I liked:
    • The aforementioned 4-way switch
    • 1-11/16" nut width
    • Electrosocket jack
    • Strap locks
    • 8-hole pickguards
