What is “the” router these days
Mojotron
Seattle
For quite a while I used a Dewalt router - I liked it quite a bit and I've used a Bosch 1617EVSPK for about the last 10 years - never had a problem. Since I use so many jigs, I plan on just sticking with the router I designed them for and I'll stick with the Bosch. I like the 690 because it's a bit lighter and smaller though.
old wrench
corner of walk and don't walk
For me - Porter-Cable was always synonymous with quality, although their last few years of designs and production might be a little questionable.
I didn't know that P-C folded - they were an American tool institution
But, I do have enough P-C routers (3) to see me out the final door
For other current production routers - I have a Bosch Colt (original 1hp version) that I like pretty well - it's very smooth-running, although it is a little difficult to dial-in really fine height adjustments.
A router is a pretty simple power tool - as long as it has a decent motor, a good collet system and a reliable way of making height adjustments, it has good potential
Plunge routers are a bit different - I've seen that there is quite a bit of difference between how smoothly that plunge mechanisms work on different models
Jim_in_PA
SE PA - Doylestown PA
Pick your color preference. DeWalt (yellow) Bosch (blue) Makita (Teal), etc. They and other have decent offerings with the most versatile for general woodworking being the midsize (12 amp) kits with multiple bases. For guitar work, many people do like the smaller trim routers for the lighter tasks.
My primary hand-held routers are Festool and my table has a big, old PC 7518, but I have a DW618 Kit from DeWalt that covers all those things were a low center of gravity fixed base router is optimal. The DeWalt has been an excellent tool for me.
Hags
Northwest CT
If you need precision and reliability
Freeman Keller
Many lutherie gizmos are drilled to fit the Bosch Colt laminate trimmer base. I also just read an interesting article in American Lutherie magazine where they author advocated buying a 25 dollar Harbor Freight laminate trimmer for each task that you do and setting it up to perform just that task.
crazydave911
East Tennessee
For a laminate trimmer (small router) I've had good service from my Ridgid trimmer. Variable speed and the base fits my attachments I made for my old Ryobi. Only issue is you need to 3 in 1 oil the collet quite often as it tends to seize
RickyRicardo
Calgary, Alberta
I bought 2 refurbished Bosch 1617's that looked like they were never used at all. One is for the table and the other as my plunge. I've had them for 9 years and they've been flawless.
Timbresmith1
Central TX
Bosch has the clunkiest plunge mech, imo. The dewalt 1 1/2 hp is excellent, and the Makita plunge, also.
Chuckster
Boston/Cape Cod
I have Porter Cable in my table, and a Bosch Colt for trim and pickguard work.
I need a good plunge setup, and I'll probably grab an M18 Milwaukee for things around the house.
Mojotron
Seattle
Yep, I’ve been using my Rigid laminate trimmer for a lot more of the steps in making guitars - it’s the perfect tool for using with smaller jigs. Most of the early jigs I made were huge and kind of clunky just because my normal router was twice the size and 3 times the weight. That’s what makes the 690 a great jig router, it’s smaller/lighter when power is not needed for guitar making most of the time. The laminate trimmer is a great tool I use more with each project.
scubadoo
Bristol, UK
I used to use the Bosch twin base one but it failed after a year or two, got repaired and failed again as did the Bosch Jigsaw.
So now I have the Triton TRA001 in the router table. I don't love the build but it has the built in router lift for above table adjustment and plenty of power. And to be honest, taking the router motor out of the table all the time was a pain. I if was doing it again i'd look at a more precise lift and a motor for the table but the Triton works just fine.
For handheld I use the Festool OF1400 and a Makita trim router. When i started I could only afford one router but it's worth thinking about 2 in the long run. You even go one in the table and a trim router for body roundovers and cavities. Especially if you make a base with handles.
New Posts
