UserNotAvailable
CAUTION: thinking about this can cause Tumors!
Well, you're exactly right. Nobody would have been clamoring for a stiped down second Fender guitar if the Strat had been first, just like nobody would have been asking for a heavier Gibson if the SG had been first. IMO.Maybe Leo got it right the first time, but wat if he made a Strat first? Would you have been asking for only two unbalanced pickups, only three saddles, no upper horn for balance, no comfort body contours, a simpler headstock, no trem? I mean, if history is set aside, what are the features that make a Telecaster so special for you?
(And if your answer is « twang » , please explain how to implement it into a strat.)
Instead of "belly cut," why not call it a "rib cut," because that's where the Tele top edge gets me.
Yes, they all looked like leave it to beaver.Most people were pretty thin before the 1980s...![]()
People don't wear guitars high any more?where i wear the tele (same position as seated w/ leg over), it just sits flat on my ribs. guitars with contours where they angle dig right into them.
the contour was done with the intention of playing guitar sitting down. for that it works great, it puts the thing right up against your breast at a 45, and it also angles the bottom edge forward on your leg, jazz style.
but it doesn't work like that when you stand with it. the bottom edge doesn't angle forward and the angle of that cut sits in a weird place if you keep it as high as it is when you sit with it. so you have to play it lower and sacrifice some left wrist range of motion/play differently than sitting. which you don't have to do at all with most other guitars.
it's not like guitar players didn't ever stand before 1954, and when they did, they wore the guitar high. so IMO it wasn't horribly thought through. rock guitarists playing low is the only thing that made it a non-issue.
Leo always developed the solid body guitar. He saw the Strat as a development of the Tele, not a new instrument.As I recall, Leo was 1) pragmatic, and 2) not ashamed to take other people's ideas. Or their lead, if you prefer.
Look at this, from the late forties. See anything that looks familiar?
Over time, Leo would have continued to develop the Tele. Just as Fender has since his passing. The quick-change neck and straight-pull string setup were destined for greatness.
