What has happened to my tele?!?!
Discussion in 'Tele-Technical' started by johmica, Jan 8, 2012.
  1. johmica
    johmica Tele-Meister
    Berea, KY
    I was playing my tele custom this morning, and everything was fine. Played for a couple of hours, and then hung the guitar on my wall and left it for a few hours. Came back, and now, all of a sudden, my bridge pickup is acting all funky.
    I get normal volume up until around 7 or so, and then from 8 to 10, the volume decreases until it's completely silent at 10. I've never had this problem before. What is going on?
    Edit: I just noticed that the neck volume pot is controlling the bridge volume, even when the pickup selector is on bridge only. Did something just ground out on my three way switch?
  2. boneyguy
    boneyguy Doctor of Teleocity
    victoria b.c. CANADA
    That would be my first guess.
  3. johmica
    Berea, KY
    Just opened her up. There doesn't seem to be any grounding issue, and the pickup itself is still reading 5.9 ohms (or micro-ohms, or whatever they are). The point is, the pickup still has output, but only when removed from the pot. I checked the neck pickup with solder joints intact, and it reads fine. But the neck pickup only reads output when removed from the pot. Bad pot? Still a chance it's a grounding issue? Any thoughts? I'll probably just take it to my guitar tech in the morning. He just re-wired it about three months ago. Maybe I can get some kind of "warrantied" repair done . . .
  4. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    Spray the pot out with contact cleaner and spin the knob around a bunch in the process.
    May be just some funky crap in there. Do 'em both.
  5. megafiddle
    megafiddle Former Member
    VA
    What pots do you have on there, function-wise?
  6. johmica
    Berea, KY
    Not sure I understand the question, but I've got two volume and two tone pots. All 1 meg CTS pots. Like I said, everything has worked fine for months now, and I was playing it this morning without problem. Set it down, turned off the amp, and came back later to no volume on the bridge pickup. When I set it on 5, I get about a third of the volume I should have on 5, and that's all I get. It's downhill from there. And I can kill the volume on the bridge pickup completely by turning the neck volume knob to zero with the selector in the bridge position. I'm puzzled, for sure.
  7. rolling56
    rolling56 Friend of Leo's Silver Supporter
    Mangling notes since '81 in SW Misery
    Since you have a VOM fix it yourself ;) Your tech will just make more $ off of you.
  8. johmica
    Berea, KY
    Unfortunately, I wouldn't know where to begin. I'm a plumber, and I've got a multimeter for water heaters and such. I can understand in theory how one would try to isolate individual steps in the circuit to locate the problem, but practically, I could spend days trying to figure out how to do it.
  9. sjtalon
    want days or minuets ? it's worth a try:
  10. johmica
    Berea, KY
    I'll try it, for sure. To quote the general in "Wargames," I'd piss on a spark plug if I thought it'd do any good.
  11. sjtalon
    BWAAAAA
  12. sv9cannon
    sv9cannon TDPRI Member
    Columbia, SC
    You sure you're turning the knobs the right way..?
  13. TC6969
    TC6969 Friend of Leo's
    Wimauma Florida
    I don't think dancing is going to help this situation.
  14. dog fart
    dog fart Friend of Leo's
    North Carolina
    Sounds like a faulty volume pot. I'd start with the cleaner. If that doesn't work replace the pot. I'd be very suprised if the cleaner doesn't do the trick
  15. sjtalon
    Oooops ! dang Firefox spell check let me down again :eek:
  16. johmica
    Berea, KY
    The cleaner had no effect. The frustrating thing is that the pot is barely three months old. I can only assume that the pot is the culprit, however. Taking it to my guitar tech in the morning.
  17. daniel o
    daniel o Tele-Meister
    manitoba
    what was the outcome of the visit to the guitar guy? issue corrected?
  18. Geo
    Geo Friend of Leo's
    Hendersonville, TN
    I'll guess a couple wires have come in contact or just one is grounding
    against a pot lug.
  19. lostpick
    lostpick Tele-Afflicted
    Staten Island, NYC
    there is probably a way to jumper the pot and
    get into no-load mode...
    if it comes back strong and bright...its the pot
  20. Geo
    Geo Friend of Leo's
    Hendersonville, TN
    If it isn't the pot could be a capacitor leg has toched a wrong spot on the pot.
