What glue should I use to keep the plastic toggle in place?
Discussion in 'Telecaster Discussion Forum' started by Revelation, Aug 13, 2018.
  1. Revelation
    Revelation Tele-Meister
    PA
    My Tele cap on the pickup selector can come off if you move it too fast. What glue to you recommend to keep it in place?
  2. Rhomco
    Rhomco Friend of Leo's Gold Supporter
    DFW, Texas
    Don't glue it. Crimp it with a Wire Cutter (Dykes). I like to put two or three crimps along the thin edges so that it will grab the knob when you put it back on. You can still pull it back off if need be but it wont just slip off unintentionally.
    Good luck with your project,
    Rob
    nojazzhere likes this.
  3. Sea Devil
    Sea Devil Tele-Afflicted
    Brooklyn, NY
    One drop of superglue usually does the trick. It can be a bit of a PITA to pry off if you need to remove the switch, but it's not impossible. Some people just use masking tape or teflon tape to make it fit more snugly.
    rich815 and knockeduptele like this.
  4. brookdalebill
    Austin, Tx
    I’d get a switch tip with a set screw.
    Rutters and a few other companies make em’.
    Personally, I converted to a Gibson type selector switch.
    Problem solved, for me.
    I got tired of knocking switch tips off, and losing them.
  5. JL_LI
    JL_LI Friend of Leo's
    Long Island, NY
    Silicone glue is your best bet. You may know it as aquarium cement. It holds well enough that the switch tip won't slip off but not so tight that you can't get a good grip and remove it. Best of all, any residue peels off without damaging finish or plating.
  6. telemnemonics
    I usually just find a tighter fitting switch tip, but used to crimp the switch end when parts were harder to find.
    If you want glue I'd choose locktite thread lock, which is designed to put on bolt threads so the nut won't rattle off, but there is a version that only keeps it tight and can be removed and reinstalled.
    LouBluz likes this.
  7. jackal
    jackal Tele-Afflicted Gold Supporter
    mojave desert
    Very small piece of double sided tape works for me.
    dustoff and moosie like this.
  8. beagle
    beagle Friend of Leo's
    Yorkshire
    I always used to use a bit of the gummed paper from a page of stamps, licked and folded over the switch. I don't know what I'll do now the stamps are all self adhesive peel and stick...
  9. Tim S
    Tim S Tele-Holic
    Upstate NY
    Painter's tape or plumber's tape has been known to keep some folks. Glue can be a little too permanent sometimes.
  10. nojazzhere
    Foat Wuth, Texas
    Like the thread on "string caps" (ferrules) coming off, I've never experienced a switch tip coming off either. I do use a smaller "Strat"-style tip, rather than the larger "Tele"-type, but I don't think that changes anything......stop doing Pete Townshend "windmill" stuff. ;)
  11. Tim S
    Tim S Tele-Holic
    Upstate NY
    And leave the fans disappointed? :eek:
  12. Crobbins
    Crobbins Friend of Leo's Ad Free Member
    Meiners Oaks CA.
    Use something doesn't glue it on permanently.
  13. Tim S
    Tim S Tele-Holic
    Upstate NY
  14. dinomike77
    dinomike77 Tele-Meister
    I wrap the switch in a small bit of electrical tape and jam the tip down on there. If there’s any excess hanging off, I just cut it with a box cutter blade.
  15. PCollen
    PCollen Friend of Leo's
    Man of the World
    I can't think of any reason to have to remove the switch tip unless the switch itself needs to be removed. And I can't think of any reason to have to remove the switch unless it is so defective beyond repair and needs to be replaced, as there is really no repair to the switch that can't be made with the switch in place. So if you can't repair the switch in place, then you should just replace it with a new one and, in that case, just cut the switch tip off, replace it, and get on with you life. How's my spelling ?
    Texicaster likes this.
  16. jimgchord
    jimgchord Tele-Holic
    victor,ny
    If you're gonna glue metal to plastic than epoxy is your best bet. The only reason you'd ever want to get it off is to replace it or the switch, on that case just slice it off with a utility knife
    PCollen likes this.
  17. DavidP
    DavidP Friend of Leo's
    Vancouver, BC
    ...+1 on teflon plumbing tape. That usually does it for me. Otherwise, a lil' dab of silicone on the switch tip also works fine...
    esetter and PCollen like this.
  18. archetype
    archetype Fiend of Leo's Silver Supporter
    Williamsville NY
    Locktite Blue is removable. You don't want Locktite Red which aims for an eternal bond. :eek:
    PCollen and drmmrr55 like this.
  19. Revelation
    PA
    I called Fender, they said put a small piece of paper on the lever and push the knob back on so it's a little snug. Will give that a try
    PCollen, Texicaster and dswo like this.
  20. Texicaster
    Texicaster Tele-Holic
    Arizona
    ¡Bueno!
    That's what I did!
    Hasn't come off yet! Matchbook cover doubled over it; force the knob on.
    PCollen and Tonetele like this.
