Background: I recently bought a 1969 Twin from the original owner and IDd it as an AC568 circuit with the help of responders on this forum. I replaced the filter and bypass capacitors and a 2.2k resistor in the dog house that had drifted. Someone previously removed the large cathode resistors on the power tubes and the capacitors and wiring that were part of the bias circuit on the chassis side wall. Otherwise, it's stock with Oxford speakers and RCA 6l6gc that may be on their way out. I am hoping to get them tested this weekend. Preamp tubes are a mix of vintage and Groove Tube 12ax7s, I believe.
Question: What gives these amps their sound characteristics?
I am a low watt amp, home player. I normally play a Silverface Champ through a 2x12 cab or a Princeton 10" kit thought the cab and a 12" extension cab, so I am familiar with multiple speaker amp set-ups. Because of hearing sensitivity, I can't get on with high wattage, loud amps. So, I am not referring to the sound of an opened-up Twin moving lots of air and getting the amp and tubes in the sweet spot.
I am asking about the full, deep, rich and broad sound that comes from this amp at around 2-2.5 on the volume. It's like no other amp I've heard before. Maybe it's like other large size and wattage Fender amps: Supers, etc. but I have not played those. Once, in a Vintage Guitar and Amp store in LA, I heard someone play what I thought was a Blackface Deluxe or maybe Twin and it was amazing: similar low volume sonic bliss.
So, what is it? Tubes (large 6l6), transformers, speakers, cab, circuit, some combination of these things?
This amp has really reset my expectations and desires for what tube amps can be.
Thanks for any feedback!
