What do you use to mount your pedals onto the board?
Discussion in 'The Stomp Box' started by DatGuitarBoi, Nov 10, 2017.
  1. JORear
    JORear Tele-Meister
    Alabama
    I use Velcro purchased at our local hobby big box store.
  2. bblumentritt
    bblumentritt Tele-Afflicted Platinum Supporter
    Austin, Texas
  3. SolidSteak
    SolidSteak Friend of Leo's
    Whatever type of velcro came with the Pedaltrain Nano I bought. I need to swap stuff in and out depending on what music I'm playing.
    724SP likes this.
  4. DeVilleDude
    DeVilleDude Tele-Holic
    Hilton Head Island, S.C.
    Usually dual lock, but a few (Euphoria, Replica and QTron) I've just gone ahead and attached with Gorilla Glue. ;)
    jannodude likes this.
  5. RajDonYasser
    RajDonYasser TDPRI Member
    Right here
    When younger my friends and I always used scrap wood cut to size and drill holes to tie down the pedals. I still use this method although a lot of my buddies started using fancy pedalboards once they could afford it.
  6. ponce
    ponce Tele-Afflicted
    Croatia
    Bike here
    Obsessed and Grux like this.
  7. Grux
    Grux Tele-Holic
    Clarksville, TN
    Bike chain master links, the only way for me.
    Obsessed likes this.
  8. Jules78
    Jules78 Tele-Holic
    Northern VA
    skantzos and Grux like this.
  9. xjazzy
    xjazzy Friend of Leo's
    Portugal
    Velcro. I hate Dual lock!
    I kept my Nova System (big and heavy) attached to my pedalboard with Velcro with zero problems.
    People who use Dual lock must be throwing the pedalboards through the air!
    Righ now my Boss MS-3 is attached to a piece of wood with velcro and that piece of wood is attached to a pedalboard the same way! No problems and I travel with it a lot lately.
  10. Grux
    Grux Tele-Holic
    Clarksville, TN
  11. waparker4
    Philadelphia, PA
    I have standard loop velcro on the board. I still have enough loop velcro to cover another 2 or 3 boards. Some of my pedals have a full strip of hook velcro, and about half now have 3M dual lock just on the top and bottom. 2 roughly 1/2 square inch pieces hold the pedals down very securely without being impossible to remove. This way a package of dual lock I can get at Staples for ~$7 can cover almost ~20 pedals. I have learned to get the pedals with dual lock off with a clean 2" putty knife. It's really the best tool for the job.
    Staypuft1652 likes this.
  12. crossroader
    crossroader Tele-Afflicted
    Endicott, NY
    Zip-ties.
    I built my own boards from a pre-painted, plywood shelf. Laid out the pedals, marked them, drilled holes, wired it up, and tied them down.
    With the rubber backing or feet left on the pedals and tightening the zip-ties really snug, my pedals don't move.
    On some larger pedals I'll use 2 ties.
    Also, you use 2 ties - put one vertical and one horizontal - that pedal won't ever be sliding anywhere.
  13. LooseJack
    LooseJack Tele-Meister
    transit lounge
    I use cable ties but have not experienced this pedal swerving issue.
    I'll re-post my method from another thread.
    Cable ties and ally bars available at hardware store.
  14. the tool
    the tool Tele-Holic
    Sweden
    Topside: velcro
    Under: 3M DualLock for the ps, adapter and input.
  15. moosie
    Western Connecticut
    For those who use bike chain, or hardware solutions for 'zero movement'... try Dual Lock. Really. ZERO movement, yet it requires no tools, and you can swap pedals with one hand, should you desire. There's no goo. The adhesive is self-contained, won't stick to you, and it follows the backer. When you remove the strip, all the glue comes with it. Similar to those adhesive blobs hold credit cards on backer paper for mailing. But better.
    For those who complain about the cost or holding power of Dual Lock... don't use so large a piece! If you cover the whole pedal in Dual Lock, you may as well use Gorilla Glue :lol:.
    If I had a traveling board, where zero movement, even with baggage handlers, etc, was a requirement, I'd place a 1" square on each corner of the pedal, just inside the cover access screws. Then, either run two strips across the board, to catch the upper and lower edges of the pedals, or if everything's differently sized, just stick matching squares on the board. Or a compromise: strip across the bottom edge, so the stomps line up, and individual squares for the upper edges.
    Since my board doesn't leave the room, I only use half of this. I press the top edge of my pedals into the strip (they 'click' to lock), and the bottom edge rides loose. The pedals still don't move or shift side to side.
    This is for TWO ten-foot rolls, 1" wide. It's enough for a few huge boards.
    https://www.amazon.com/dp/B007OXK1AK/?tag=tdpri-20
  16. uriah1
    Around
    IMG_3315.JPG no stick no tack. Plug and play. Imho
    jddub440 likes this.
  17. DaveKS
    DaveKS Friend of Leo's
    KS
    Yea, if your coming from Velcro world just remember that with dual Lock you only need about 1/3 of the amount of surface contact area that you used before. Put to much of it on you'll never get those pedals up without a prybar, a little dab will do ya'.
  18. Pepi
    Pepi Tele-Afflicted
    Indiana
    If I would quit getting GAS all the time I would use gorilla glue
  19. AlexEP
    AlexEP Tele-Meister
    Genoa, Italy
    I've got no problems, the cables help :)
  20. xafinity
    xafinity Friend of Leo's
    my Mom's basement
    I searched hi & lo for pics of pedal actually nailed to a board. Would you believe I couldn't find any. Is is possible nails are out of style again?
    I decided to revive some long lost skills with a few early tests on a nice piece of tonewood. No hatin! As I said these are early days as I try to resurrect classic mounting tricks.
    Loco likes this.
