What do you like/prefer for rotary effect to get your swirl on?
middy
MSP
I just use a tremolo pedal for “wobbly”. The audience doesn’t care. I do have a hankering for a univibe, though.
TokyoPortrait
Tokyo, Japan
Hi.
I too have the Fender Pinwheel.
I bought it because I wanted something ’different,’ because I generally like ‘swirling’ sounds when used a certain way, and, very importantly, because it was on sale with the equiv. of a whopping US$100 off.
It’s been approximately one billion years since I’ve heard any form of rotary speaker in the flesh, so I can’t speak to how accurate it sounds, but I do like it.
The (horror, digital) overdrive part sounds great, and I like that you can set the ‘spin’ to be triggered by how hard you play, via the sensitivity knob. That plus the adjustable ramp up/down speed make it fun.
It’s cool for home recording too, running the left and right outputs into separate inputs on my interface for separate tracks that can then be panned. Sounds great.
It’s not small though. And can be fiddly to set right.
Pax/
Dean
E5RSY
Georgetown, TX
I use a couple of different pedals to get me there. The Ventura Vibe and the MXR Micro Chorus.
The Ventura Vibe is great in that it has a killer rotary sound, but it also has a good Uni-Vibe setting as well as a "Modern" vibe option. A lot of utility in one solid little pedal with great sonics.
On the other end of the spectrum, I love the Micro Chorus, too. Believe it, or not, it pretty well nails Jimmie Vaughan's Vibratone sounds from "Couldn't Stand the Weather" (especially on "The Things That I Used To Do"). Can get some respectable Scofield-ish sounds, as well. I marked mine with the Vibratone's slow and fast settings for quick reference.
E5RSY
Georgetown, TX
From a practical standpoint, the best one I've used is the Ventilator pedal. But it still does not completely create that somewhat disorienting 3-D room effect.
So I built a Leslie clone. It captures the magic. If I can do this (I'm all thumbs), so can you...it was really not difficult at all.
Build thread here: https://www.tdpri.com/threads/leslie-in-a-box-mission-complete.1031934/
I did make a vid of it to post to YooChoob, but even when recorded with XY stereo mics in the room, it sounds like a stereo Leslie pedal. You need to have your ears in the same room as the cab to fully appreciate the effect.
Just checked out your build thread. Wow, man. Incredibly cool. Still running well?
Peegoo
Beast of Bourbon
Thanks, brother.
Yep, it is a permanent fixture in the front room. I've been driving it with a Roland Microcube; it's plenty loud.
red57strat
Massachusetts
I had a Leslie 145 and a Hamptone preamp to run it for years. It was magical, but too big for anywhere I'd play and a hassle to move.
I bought a Hughes & Kettner Rotosphere when they came out and it was good, but noisy, it didn't fit on my pedalboard, and it had special power needs.
I replaced that with a Tech 21 Rotochoir well over 10 years ago. It turned out that I was after more of the Leslie 125/Fender Vibratone sound.
I love sound of the Rotochoir, though it has a few pretty inexcusable issues-
-there's no brake
-there's no indicator telling you what speed it's set at
-the speed changes when you switch from Leslie 122 to 125 and back depending on how you have the speed set
ruger9
Hackettstown, NJ
-there's no brake
So... have you tried any of the newer ones? Strymon Lex, Neo Ventilator (and their smaller ones), etc?
ruger9
Hackettstown, NJ
I haven't. I kinda settled into what I've got.
So the Tech21 claims to do a Vibratone? I also was searching for a Vibratone, not a Leslie. I tried the Tech21 and didn't like it.
I know the new Lex v2 will do a Vibratone (if you run it a certain way), and Neo has the "Micro Vent 16" pedal, which claims to do the Vibratone. $$$$
RCinMempho
Maryville, TN
Line 6 Roto-Machine
Me too. Good enough. Lots of tone adjustments and it ramps up and down. Had it for decades now.
In the 70's I would combine amp tremolo with a Bad Stone Phase Shifter. I'd get the phaser going and then tweak the tremolo by ear. Frankly, that was an excellent swirly sound. I may go back to that.
E5RSY
Georgetown, TX
A 2-stage phaser, like a Phase 45 or DOD 201, cranked up does a pretty good imitation, as well. Plenty good for stage use at a typical gig.
SpaceAceman
Tampa Bay
My swirl of choice is a Chorus. Just the prettiest sound ever, and a perfect thing to fatten up a single guitar sound as long as it isn't to syrupy!
However - I have a serious Tremolo fetish...
