What do I do with a bias adjustment on a Princeton Reverb?
Discussion in 'Amp Central Station' started by dnauheim, Oct 15, 2020.
  1. dnauheim
    dnauheim Tele-Meister
    Charleston, South Carolina
    I just got a '69 Princeton Reverb. It has a bias adjustment installed. Never had one of these--what the heck do I do with it? Will it change the tone? Do I risk burning up my tubes if I set it wrong?
  2. schmee
    Yes you can burn up the tubes if it's set wrong. Setting bias can make an amp sterile or sweet or in between. You need something to measure the bias. It can be a Volt Ohm Meter and a $14 item that goes in the tube socket, or you can buy a little device that makes it easier for more money, or there are other means to do it.
    Probably best to google how to do it.
    Nice find on the amp! I'm 70 miles north of Seattle.
  3. wmsimpson
    wmsimpson Tele-Holic
    Greater Puget Sound
    Congrats on the new '69 PR! Super nice amp! I picked up a '71 PR a couple years back and installed a bias adjustment pot in mine. If you ever need to have it checked or adjusted, you'd be welcome to drop it off here at my house, and then pick it up in an hour or so. I have all the needed equipment... and I'm just out in North Bend.
  4. corliss1
    Lansing, MI
    If it's a 69 it would be good to know the service history, but for normal amp use you never need to touch the bias adjustment.
  5. EsquireBoy
    EsquireBoy Tele-Afflicted
    Paris, France
    Since the PR has a bias tremolo, you can use the latter as a reference when adjusting the bias by ear: the hotter the bias, the less depth the tremolo has.
    Set the tremolo intensity halfway up (NB: the knob won't necessarily be at noon, depending on the taper of the pot). Then play with the bias adjustment knob by very small increments and hear the difference in the amp's tone: as long as you still have good intensity on the trem, the bias should be within safety for your output tubes. When the tremolo starts to really fade (while still set halfway to the max intensity), you may be entering the danger zone.
    This method surely does not replace proper measurements but it's a good safety net when you just want to experiment a bit with the bias knob to hear what it does to the sound of your amp.
    dnauheim likes this.
  6. dnauheim
    Thank you Esquire, I'll try that!
    EsquireBoy likes this.
  7. dnauheim
    That's very kind of you! I am not in Seattle anymore though, but I can't figure out how to update my profile!
  8. EsquireBoy
    Paris, France
    You're very welcome. That's how I set the bias on a friend's PRRI without anything to take actual measures, and it's running nice and smooth.
    Just remember to take note of the initial position of the bias knob in case you want to come back to it.
  9. wmsimpson
    Greater Puget Sound
    Go to the top of the page and set the cursor to hover over your user name. A drop down menu should appear, click on personal details. Change your location.
  10. dnauheim
    Thank you! If only adjusting bias was that simple!
    wmsimpson likes this.
  11. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Be careful. If you have a 69, it may have the older Champ-based power transformer, which are marginal - does it have a GZ34? Some people crank the bias to try to get more power, but that will just heat up the PT and you'll see your B+ voltage drop. As Esquireboy noted, the trem drops out as bias goes up.
  12. dan40
    dan40 Tele-Afflicted
    Richmond Va
    And be careful if the bias pot is located inside of the chassis. There will be 400vdc inside the chassis that can get you if you touch the wrong spot. Use an insulated screwdriver and do not touch anything else unless you are experienced working on live circuits.
  13. dnauheim
    It has a 5U4GB. Not sure the significance of that, though.
  14. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    If you don't know what you're doing, best to leave it alone or to a tech.
    teleman1 and radiocaster like this.
  15. Dacious
    Godzone
    Ok that's good. 68/69 was the crossover year, Fender went to the 5U4 and a bigger PT which had 3A vs 2A and 90ma vs 70ma B+. They're a bit tougher.
  16. dnauheim
    I just checked and the tube chart actually calls for a GZ34 so . . . what then? It is alslo lists AA764 as the circuit. However, there is not guarantee the chassis is the original that went with that cabinet, that went with that tube chart . . .
