What can I use to remove sticker residue from rosewood fretboard
Discussion in 'The DIY Tool Shed' started by GregSt, Mar 21, 2021.
  1. maxvintage
    maxvintage Poster Extraordinaire
    Arlington, VA
    Boiled linseed oil will not get gummy--it's a curing oil, that's what the "boiled" part refers to
    Acetone doesn't hurt poly
  2. Collin D Plonker
    Collin D Plonker Tele-Afflicted
    Delaware
    Acetone may melt the inlays. I would try naptha (lighter fluid).
    Boreas likes this.
  3. maxvintage
    Arlington, VA
    Right I already said that, see above in the comment you copied and pasted
  4. GregSt
    GregSt TDPRI Member
    Victoria
    Wow, thanks for all the responses, I’ll try some naptha first I think, see how it goes.
    John Owen likes this.
  5. Chas3rd
    Chas3rd TDPRI Member
    Topeka, Kansas
    Try warming them with a hairdryer and carefully and slowly peeling them off.
    Asmith, Boreas and guitargeek like this.
  6. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    An even simpler way to remove sticker residue is to rub it with a thumb or fingertip to create friction, build a little heat, and the stuff rolls right up into little toe jam footballs.
    And yeah--that is the origin of that term from the Beatles' tune Come Together.
    smoothrecluse and guitargeek like this.
  7. guitargeek
    guitargeek TDPRI Member
    frankenmuth
    I use a hair blow dryer to heat up and remove stickers on bicycles and cars. It works like a charm. I would go in slowly on a guitar. I am not sure how immense heat would negatively effect a guitar.
    I use goof off if I don't care about the surface underneath. But man, that stuff is strong - use outdoors.
  8. benderb9
    benderb9 Tele-Afflicted
    St Petersburg,FL
    Goo Gone is good and doesn't absorb into the wood, the glue residue will roll off. I also use it for wiping off dust with a lightly moistened rage on electronic stuff and it's gold.
  9. benderb9
    St Petersburg,FL
    lighter fluid also works, usually and doesn't do any harm to lacquer
  10. jms2009
    jms2009 Tele-Meister
    Charlotte, NC
    Naphtha
  11. Fuelish
    Fuelish Tele-Holic
    foothills of the Great Smoky Mountains, east TN
    I’d use alcohol, moderately, dry, and oil the board. I usually come home from work with several packaged alcohol swabs in my pocket... they’re kind of handy to have
    irie likes this.
  12. OneChosen2
    OneChosen2 TDPRI Member
    Saint Augustine, Fl
    I haven’t seen 0000 steel wool mentioned.
    I would imagine some fretboard conditioner with some LIGHT steel wool scrubbing would make it like new.
  13. irie
    irie Tele-Holic
    Nashville, TN
    Naptha or rubbing alcohol
  14. zekester
    zekester TDPRI Member
    Brooklyn, NY
    Use naphtha (old-fashioned lighter fluid). It will not harm the wood of the fretboard and evaporates quickly. DO NOT USE ANYTHING ABRASIVE LIKE STEEL WOOL WHICH HAS THE POTENTIAL TO REMOVE WOOD.
  15. zekester
    Brooklyn, NY
    GooGone contains petroleum distillates in addition to citrus oil.
    Drew617 likes this.
  16. Tele Plucker
    Tele Plucker Tele-Meister
    Alternate Universe
    I’m told by my younger brother/guitarist that plain old lighter fluid does the trick with adhesives with no damage.
  17. stepvan
    stepvan Tele-Afflicted Silver Supporter
    out there somewhere
    What about lighter fluid ?
  18. Warren01
    Warren01 Tele-Meister
    Castlegar BC
    Just hit it with an angle grinder. That sticker won't know what hit it.
    aging_rocker likes this.
  19. THX1123
    THX1123 Tele-Meister
    A part of NY that's far from NYC
    You could use a guitar rosewood fretboard sticker glue residue remover tool and fluid. Or saliva and an old T Shirt.
  20. Chiogtr4x
    Chiogtr4x Doctor of Teleocity
    Manassas Park, VA
    Curious, where did you get the inlay stickers?
    Were the specifically designed to be fretboard inlay stickers?
    Thanks
