What adhesive to use to attach paisley paper to body?
Discussion in 'Finely Finished' started by Kloun, Apr 22, 2021.
  1. Kloun
    Kloun Tele-Holic
    Orange County California
    I am going to be doing a jazz bass body in black paisley. Want it to look like this:
    I will be using gift wrap paper with a paisley pattern, because I like the pattern and color. This is it:
    The paper itself has no adhesive backing, so I will need to use my own adhesive. What would be the recommended adhesive to attach the paper to the body. I am particular concerned that it can be applied evenly so there won't be any bumps or wrinkles when I attach the paper. Any recommendations? Thanks.
    Skydog1010 likes this.
  2. _MementoMori_
    _MementoMori_ Tele-Afflicted
    The Bible Belt
    Is this how paisley is applied? It seems destined for failure, though I admit to knowing nothing about paisley finishes. Something like a paisley vinyl wrap seems a lot more fool-proof, since you're not opposed to wrapping the body anyway.
    Boreas likes this.
  3. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    I don't know. But it might be a problem applying it to a black body. It may really darken the paper. Perhaps apply it to a white background first?
  4. Kloun
    Kloun Tele-Holic
    I will be applying it to a bare body with sanding sealer applied. This is how it was originally done in 1968.
    See: https://www.tdpri.com/threads/original-1968-69-paisley-paper.1042357/
    In 1968 Fender used a product called "Cling Foil" which was what was used to line shelves and drawers. The paper had adhesive to it. It is no longer made, but it's the same principle and I just need to use adhesive to attach. Once the paper is attached I will use black paint to outline a sunburst on the body then top it off with clear nitro. Just want to figure out what to attach paper to body with.
    _MementoMori_ likes this.
  5. _MementoMori_
    The Bible Belt
    Very cool. Thanks for the history lesson! It's a shame you can't find something that has the adhesive pre-applied. I feel like oversaturating the paper or the body with adhesive could really botch the entire project. It sounds like you know what you're doing though.
  6. Danb541
    Danb541 Friend of Leo's
    Oregon
    these guys use fabric with great results. You'll have to search more of their videos for how they finish them.
    Wound_Up, Skydog1010 and Kloun like this.
  7. mkdaws32
    mkdaws32 Friend of Leo's Gold Supporter
    Moncton, NB Canada
    That fabric video is great. I was thinking of doing a body with denim-look fabric.
  8. Kloun
    Kloun Tele-Holic
    Actually they do have specialized decals with adhesive already on them.
    https://www.rothkoandfrost.com/guitar-making-supplies-c83/paisley-pattern-body-decals-c52
    It's just I don't like the patterns that they have available and I don't think it would work with a black sunburst finish. The stuff they have would look good for other colors, but not really black. It's also alot pricier than using gift wrap.
  9. Mad Kiwi
    Mad Kiwi Friend of Leo's
    Land of the Long White Cloud
    I cant see why a thin smear of PVA on the wood wouldn't work?
  10. Kloun
    Kloun Tele-Holic
    I found this video from the video that Dan linked. It appears to be what I was looking for. Thanks!
    Skydog1010 and Danb541 like this.
  11. Boreas
    I don't think there will be an easy answer without experimenting. Depending on the solvents in the adhesive, it could easily cause the ink in the paper to bleed together.
    They do make adhesives for attaching prints to posterboard before framing. I believe it is sold in sheets and activated with heat. You may want to speak with someone who does framing and ask them about mounting paper. It would also give you a brighter background than the wood in the guitar.
    Peegoo likes this.
  12. stratisfied
    stratisfied Tele-Holic
    Midwest
    Spray Photomount by 3M. Coat both surfaces for a permanent bond. As an alternative, you can take the body and pre-cut paper to your local picture frame shop (like Michael's) and they can dry mount in their press. The adhesive they use is sheet adhesive which is pressed flat and heated for a permanent bond. They will charge the same as photo/poster of the equivalent size.
    Kloun likes this.
  13. PeterUK
    PeterUK Poster Extraordinaire Silver Supporter
    Nottingham, UK
    Kloun likes this.
  14. Wound_Up
    Wound_Up Tele-Meister
    Shreveport, LA
    Use fabric. Texas Toast Guitars on YouTube has vids showing exactly how they do theirs. This Yngwie Malmsteen Strat came out great! They even did a burst on the headstock to match. They use titebond to glue down the fabric. Then seal it with sanding sealer, I think.
    He applies the fabric to the Yngwie Strat in this vid below
    Edit: I see someone shared one of Matt's vids already. Nice job @Danb541
    Kloun likes this.
