Wet dry wet stereo pedal board sized amps.
Discussion in 'Amp Central Station' started by Newbcaster, Feb 4, 2019.
  1. Newbcaster
    Newbcaster Tele-Holic
    Gilbert
    Hey folks. I plan to start gigging again. It's been a long time. Like many of you I've got all the amps I could want for my studio really, except for a gibson 20 watt, an old scandal and a hi watt slave.
    I'm 44 now and all Marshall stacks and fender bassmans are just too heavy and too damn loud.
    What I think I need is these new to me pedal board sized micro amps.
    What I theorize the signal chain to be is:
    Guitar-4knob tube driver-thorpy gunshot-10 ton hammer-univibe-sliderig compressor-bbe sonic mazimizer-
    Amp1-demeter real reverb- stereo tremulator-boss space echo, boss chorus-splitter-amp 2-amp3
    I could be persuaded to have all 3 the same or different.
    I have custom 1 speaker boxes for each amp, very light.
    What mps should I buy?
  2. Thin white duke
    Thin white duke Tele-Afflicted
    italy
    I'm 44 like you and i'm building a wet / dry set up. :):):)
    I'm using 2 Vox Pathfinder rehoused in 2 different cabs, in one a use a 1x12 speaker that i already have and the other the wet side i'll be probably using a 1x12, i take the heads off the Pathfiner 10 and use them with the new cabs, they have plenty of volume and a nice line out.
    Newbcaster likes this.
  3. Jef
    Jef Tele-Holic
    Antwerp, Belgium
    I'm 42 myself... ;-)
    I'm using two Peavey Bandits for the wets ( a 65 and a teal stripe 112).
    at the moment I'm converting an old stereo record player with two 6 watt tube amps inside as a stereo amp for the wet signals (with two 8" cabinets).
  4. VintageSG
    Yorkshire
    If you're handy with basic tools, there's stereo Class D boards aplenty on Etat etc. They are rated rather optimistically, but if you consider they're advertised at twice the actual power you'll not go far wrong. They're cheap, effective and sound rather good. Add in a PSU, some socketry and a case and you're in business.
    That's one option for the dual wet side(s) of things. I've played about with plenty of these cheapo boards, from a couple of Watts stereo to a 50 Watt mono and many points in between and they're a bargain. Go for a switched mode 'modular' PSU rather than a traditional transformer/rectifier/cap bank or your costs will spiral.
    Electro-Harmonix market the Magnum 44, which is a mono Class D in pedal format. Fine sounding and barking loud. The PSU is twice the size of the amp though, and is a large laptop type.
    Mooer market the Baby Bomb, another mini Class D in a pedal format. Youtube reviews seem generally favourable.
  5. Newbcaster
    Gilbert
    what is etat??
  6. VintageSG
    Yorkshire
    Ebay. The electronic emporium of tat, plus amplifiers :)
  7. Newbcaster
    Gilbert
    so the whole idea of this is to make everything lightweight and on wheels... what are people doing for speaker cabs?
