Western Cedar, wenge neck, Jazzmaster - Brotherhood Build
Jim_in_PA
SE PA - Doylestown PA
If my left hand actually still worked normally I could still play :(
Yes, that's kinda similar to my issue, but it's my left wrist. Surgery a few years ago for bone-on-bone required removal of three bones to fix and I did not regain more than about 35-40% range of motion, so it's hard for me to finger the fretboard reliably. The scary thing is I may need to eventually get the right one done. It hurts more than the left ever did, but I've been, um...avoiding it. At any rate, Scott's build is amazing and I have no doubts it sounds great!
crazydave911
East Tennessee
Yeppers :)
Moodivarius
Northwest Ontario
Mixed some different colours to see what I will use to tint the lacquer for the transparent coat.
The real colour, is slightly more green than the photo.
Came up with these.
I’m liking the middle.
Scott
Moodivarius
Northwest Ontario
Mixed up some more colour for the nitro lacquer. What I had previously, wasn’t enough to tint properly.
Strained through t-shirt about 3 times & coffee filter.
I ended up with 6oz of tinted lacquer.
Hopefully that should be enough for body & headstock.
Might try & spray today. Have to warm the shop, since we woke up to -30C/-22F.
Scott
skipjackrc4
Looking good! I love the stainless fret markers. Have you noticed any problems with the fretboard shrinking back and leaving sharp edges at the markers?
Moodivarius
Northwest Ontario
No.
And at the moment, running wood heat in the house, & low humidity in the winter, the wood should never shrink any more.
Less than 40% humidity in the house, with the body & neck hanging a few feet from the wood stove.
Scott
Freeman Keller
No.
Scott
Don't let the RH get too low, Scott. 40-45 is my target, when it drops to 30 I worry. Everything stays in cases with humidifiers anyway. I get to fix a lot of dry guitars each winter and it is totally preventable.
Moodivarius
Northwest Ontario
Well,
Sprayed some colour. Not sure how I like it. I used the 6oz, & not enough to even things out. Might end up going for a solid colour.
The first coat ran slightly in one spot. I guess I put it on slightly too heavy. Seemed like nothing was going on.
Might just go find some Dupli-Color that is close to this.
Scott
