I have a cheap little Marshall tube combo that sounds great for clean sparkly surf tones, but there's no reverb on the amp. So off I go to Frankenstein this thing and install a reverb. My plan is to place a reverb pedal's board in the chassis in series with the onboard effects loop. I'll also add a small 9vDC power supply inside the chassis, which will allow this to operate just like amp reverb when I step on the loop button.
My go-to simple 'spring' reverb has been the T-Rex Tone Bug Reverb for almost 20 years on, but these are no longer made. I went onto the usual scumbag auction sites and these are available, but I didn't want to buy something that may be worn out, been abused, etc. So I rolled the dice on a cheap Amazon unit, with no reviews. I figure if it's junk, I'll send it back, right?
But gotta say it sounds really REALLY good; it has that characteristic spring delay/snap of a long tank unit. The volume does not change when engaged and bypassed. The single depth control works smoothly through the entire sweep from no reverb to more than you'll probably ever need, and it sounds good through the entire sweep. It's in a small aluminum box with good-quality components.
I'll post updates to this project over in the Amp Mods section as this gets going.
If you're looking for a really simple reverb with an on/off switch and one knob, give this Kokko Space pedal a try.
Turns out there are reviews on YT. Here's one. The guitar is a bit outta tune, but it's close enough for rock and roll.
