Weird Tweed Power Trans in Brown Fender Super
Discussion in 'Amp Tech Center' started by ocduff, May 13, 2019.
  1. ocduff
    ocduff Tele-Meister
    Thanks for vote on the PT originality. From what I can find on internet the 6516 was an early tweed Twin transformer - 5C8. Again, weird.
    Looking at the way it's wired in, and the solder joints, it definitely gave me pause.
    It's a 6G4-A circuit. 6 preamp tubes. 68k resistors tied to input jacks.
    Re: voltages: I've got -57 at the bias supply cap. 455v on plates and 32ma bias. That's pretty darn close to spec and I'm certainly not alarmed by those numbers.
    Will post more pics of transformer wiring at rectifier when I have it open to replace filter caps this weekend.
    Thanks to all who've replied and for your enthusiasm and expertise. It's been fun sharing my new toy with you all.
    magic smoke likes this.
  2. ocduff
    ocduff Tele-Meister
    Here's the spec sheet and pic of a Triad 6516 in a mid 50's Twin.
    That's clearly not what is in this Super. Going on other pics I've found, it's more likely the PT that was found in the 5D6 and E6 Bassman.
    However I have not found pics of a PT with 6516 stamped on it, or close up of the wiring in them to see if they are wired similarly on the filaments.
    Kind of mysterious, huh? A 5E6 Bassman transformer in a later amp? Anyone here have a 5E6?
  3. peteb
    peteb Friend of Leo's
    Cascadia
    I would just chalk it up to irregularities in production due to the time frame.
    They say early Marshall amps could have transformers from three different manufacturers and still be factory stock original.
    You are right the Triad in your amp would be right for a wide panel twin, 2X6L6 and no filament center tap, but your PT looks different than the earlier TRIAD PTs. The old TRIAD PTs have the end bells that wrap around the corner.
    If your PT is stock original, then you cant ask for anything better. Can you?
  4. ocduff
    ocduff Tele-Meister
    Apologies if I'm exhausting anyone - I found an ad from 2010 for a late '61 Super Serial#440X with a 6516 PT listed.
    That's 400 serial numbers away from mine and still has same PT.
    Axis29 and Wally like this.
  5. ocduff
    ocduff Tele-Meister
    Another '61 with a 6516 PT.
    https://guitarscanada.com/index.php?threads/1961-super.87489/
    I guess a google search could've answered my question. Apparently hundreds on these supers had 6516 PT's. Several production runs. Wouldn't be surprised if Pro's and Bandmasters of late '61 also had these.
    You think Leo got a deal on some older transformers and ran with it?
    Anyway - posting this all for posterity in case anyone ever runs into a head scratcher like this one when they buy a vintage amp.
    Wally likes this.
  6. markgr
    markgr NEW MEMBER!
    new york
    Hi, I sent you a PM.
