tele_savales
I got a 1970 Bassman a while back which had some elements of an AA270 and AA371. I replaced the filter caps before even powering it on, and eventually reworked the power section to AA864 spec. The only changes I made to the preamp section were to replace the cathode bypass caps, remove the plate load resistor bypass caps, and I replaced most of the plate resistors w NOS 1 watt carbon comps. Also replaced the bias cap and reverted it to fixed adjustable bias. I put Tung Sols in the preamp and JJ 6L6's in it.
There's a strange sound that I don't recognize on the normal channel pots the increases and decreases w knob movement; it doesnt sound like frying bacon, it sounds like way more pronounced and thicker white noise than the standard plate resistor hiss. It doesn't do this on the Bass channel.
The caps themselves are the original "brown turds" of the era, which it seems most people here feel reasonably good about. I have checked for DC leakage on the coupling caps w the amp powered on and in circuit; and w one leg of the cap lifted. I haven't seen anything more than .005 vdc. I recently rebuilt a Heathkit C-3 Condenser Checker and the caps test perfectly out of the amp. The cap values themselves are pretty much right on the money. I've checked random spots all over the board for random DC and there isn't any.
I'm kind of stressing myself out for no reason, but I really don't want to shotgun all the coupling caps and plate load resistors. OTOH, I had a drip edge Bassman that I bought, buffed out, and sold, and that thing sounded epic- it had ALL the plate loads and most of the coupling cps replaced w brand new ones when I bought it...
Any other suggestions as to tracking down the source of the noise would be appreciated.
