Weird problem with a PA head, any theories?
Discussion in 'Amp Central Station' started by Mr Perch, Oct 18, 2013.
  1. Mr Perch
    Mr Perch Tele-Afflicted
    los angeles
    My band has an ancient Sunn PA head that has been very reliable. Last week, one of the clubs asked if they could play music on an Ipad through it during our breaks. We said "fine," and used the "tape in" RCA inputs. But then trouble started. We couldn't get sound from the PA when we resumed our set. We fiddled with the main volume and the thing began to work again.
    Then, last night, we turned it on and nothing happened. We thumped it and twisted knobs, and suddenly it began to work again. Then toward the end of the first set, it quit. We discovered that by turning it off and then back on, we could revive it. We had to do that again later in the night.
    This seems very mysterious. It doesn't seem to be a potentiometer problem. I sprayed contact cleaner into the main volume knob and it had no effect. Do you have any idea at all what might be causing this?
  2. chrisgblues
    chrisgblues Tele-Afflicted
    Halifax
    If it has a fuse, try replacing it. Cheap first step.
  3. Jakedog
    Jakedog Telefied Ad Free Member
    The North Coast
    If it were mine...
    First step is buy a new, reliable PA head. Something with a warranty, that you can count on. They are more affordable than ever right now. You can probably get something with more, and cleaner power, pretty cheap.
    Step two - take the Sunn in for service. If the problem is more than a hundred bucks, junk it. It's a paper weight. If you can get it fixed cheap, keep it on hand as a backup / practice space PA.
    You might not want to hear this, but that's what I call a piece of " Bic lighter" gear. You use it til it stops working, enjoy it thoroughly, make money with it, then toss it out and get a new one.
  4. Mr Perch
    los angeles
    I sort of suspected that. I owned a Fender Super Champ XD that was under warranty. When it went south, the way they honored the warranty was to give me my money back.
  5. Mr Perch
    los angeles
    Could a bad fuse cause the behavior I described?
  6. RockerDuck
    RockerDuck Friend of Leo's
    Canton,GA
    No. Sounds more like a faulty transistor that you let music pass thru, also shared with the output channel. Solid State components tend to wear out of their tolerances. Probably easy to repair, until the next one goes. I had Peavey PA over 30 yrs. I loved the tone and told everyone how reliable it was, then I turned it on one day and it bit the dirt that fast. Not worth the repair. Nor will I buy one that old used. Time for a new one. I had to get a 600 watt PA to do the same volume as that old 100 watt Peavey.
  7. syrynx
    syrynx Tele-Afflicted
    Homesick Texan in Maryland
    Homing in on the words "ancient" and "very reliable," as well as the thumping and knob twisting, it sounds exactly like an intermittent/dirty spring tension connection. I'd clean all of those I could find before spending any money: All input/output jacks (including effects return), pots, reverb tank connections, etc.
    With any old electronic gear, this is always my first step.
  8. wetblankit
    wetblankit TDPRI Member
    Kansas City, KS
    I agree with a few of the posters. Transistor or faulty connection is most likely since knob fiddling gets it working.
  9. gearhead63
    gearhead63 TDPRI Member
    Dallas, Texas
    I'd be sure to clean the on/off switch also. May have a dirty contacts making intermittent contact or low voltage.
  10. jtees4
    jtees4 Tele-Afflicted
    selden, ny
    YES....most likely the cause. I'd open it and spray contact cleaner real heavy on all the pots and switches. Cheap and easy way to begin.
  11. Mr Perch
    los angeles
    Can anyone point me to an online resource that will guide me in doing that safely? I have seen references here on tdpri to the dangers of touching capacitors, etc. I wouldn't know a capacitor from a B-bar.
  12. GigsbyBoyUK
    GigsbyBoyUK Friend of Leo's
    Peterborough, UK
    As long as it's a solid state amp and you turn it off and unplug it you will be safe. There is no real need to actually touch any components anyway.
    Don't use too much contact cleaner - just a little squirt in the pots and then rotate the knobs a few time is a good starting point. Ditto for switches.
    Also just look around inside the thing and gently touch components with a toothpick or something to see if there is an obvious broken resistor leg or something as simple.
    After that, see if an expert can take a look. I have had a few old bits of gear go glitchy like this and for not too much outlay an electrical engineer has been able to quickly find and fix it. Sometimes though they fall into the 'more trouble that it's worth' category.
  13. Mr Perch
    los angeles
    Do you think that plugging the Ipod into actually triggered the problem, or was it purely a coincidence? We never had a problem before that.
  14. buckfuzzard
    buckfuzzard Tele-Meister
    se Pa
    Just coincidence.......
    maybe a bad solder joint
  15. String Tree
    String Tree Doctor of Teleocity Ad Free Member
    Up North
    I'm with Jakedog, get a new Board.
    This one has heat issues, one thing is going to lead to another until it fails for good.
  16. syrynx
    There is absolutely no evidence that this unit has heat issues.
  17. Mr Perch
    los angeles
    As a matter of fact, I just picked up a Carvin this morning. But I hope to squeeze a bit more life out of the Sunn.
  18. vjf1968
    vjf1968 Poster Extraordinaire
    Philadelphia
    Obviously clean every contact and pot. Also get a can of compressed air and blow out any residue.
