Weight vs Tone in alder body Teles
Discussion in 'Telecaster Discussion Forum' started by BRoberts, Feb 9, 2015.
  1. BRoberts
    BRoberts TDPRI Member
    Naples, Florida
    Ok, next question for the, ahem, experts!!
    As I've been zeroing in on an AV64, I'm wondering will a 7.0lb alder body be too thin sounding(lacking mid-range)?? As opposed to 7.4, 7.5lbs?? This is one of the problems with online guitar purchasing...Any experience with alder Tele weight to sound comparisons will be greatly appreciated
  2. hemingway
    London, UK
    That seems like as good an implement as any to open a can of worms . . .
  3. Gautfrid
    Gautfrid Banned
    England
    :D
  4. waparker4
    Philadelphia, PA
    Better buy a 6.5, a 7.0, a 7.5 and an 8.0 to find out!
  5. LKB3rd
    LKB3rd Friend of Leo's
    CT
    I don't think it is going to make any measurable difference in the sound, so I would go for the light one for comfort.
  6. Mellencaster
    Mellencaster Friend of Leo's Silver Supporter
    North Bay Ont. Canada
    The word is that a heavier body adds more sustain but I don't recall hearing it changes the tone in that respect .Good luck on your tone quest ,it can be a infinitive journey ;)
  7. boris bubbanov
    New Orleans, LA + in the
    Your part of Florida is swimming (heh) with guitar stores.
    With all due respect, we don't want to hear about buying online. You're not in Nunavut - you don't have to! :)
    You do realize that the overwhelming numbers of alder guitars are in the Middlin' range, and that a starkly light Alder body Telecaster is unusual enough that there's no base of experience we can offer? If you want truly light, you have to hunt down the right ash body - or use Paulownia and pamper the heck out of it.
  8. BRoberts
    Naples, Florida
    Hahah, I've read many of the other threads regarding this, and am definitely not trying to open another can of worms. I was just wondering if anyone had found a Tele or two that sounded "just right" at "x" number of pounds...
  9. Mike Simpson
    Gilbert, AZ (PHX)
    The only difference in 2 alder guitars that have an 8oz difference in weight is one will have 8oz more weight on the shoulder strap.
    You will likely find just as much tonal difference in several guitars that all weigh the same @ 7lbs.
  10. Spaceboy
    Spaceboy Tele-Afflicted
    Richmond, VA
    weight is about comfort not tone
  11. fender4life
    fender4life Friend of Leo's
    los angeles
    I have a just over 7 Lb (maybe 2-3 oz. over) classic 60's and it's very likely the best sounding fender I've owned in 40 years of mostly fenders, and if not it's certainly as good as any I've owned at worse. Also consider this....many people have and love thinlines, and it's not the hollow factor that makes them different, it's the fact they are generally lighter. Yet may people love em. Too light IMO can be bad, but you will never find a solid tele thats nearly that light.
  12. SteveGangi
    SteveGangi Tele-Holic
    Van Nuys CA
    I'm on the side that thinks it has way more to do with the pickups, the amp, and how you set all the controls. As far as sustain goes, how much sustain does a person REALLY need? Do you just hang on that one note all afternoon??
  13. JD0x0
    JD0x0 Poster Extraordinaire
    New York
    I want more than a typical guitar puts out, clean. Compared to pianos, and bowed instruments, the sustain on most guitars is fairly short, until you start cranking up gain/compression/volume to put more energy back into the string, by getting feedback. It's a lot easier to cut a note out, on a long sustaining instrument, than it is to get a huge sustain from an instrument that doesn't sustain well, on it's own.
    I dont disagree, but at the same time, that doesn't make a body's weight or density, negligible. Everything has an effect on everything.
    In my experience, generally, heavier bodies, the notes ring out longer, but they dont seem quite as vibrant and lively, unplugged. Light bodies can often have a better resonance, they can sound brighter (unplugged) and you can often feel the guitar resonating more than a heavier one.
    For the most part the differences are subtle, and they can be masked with gain/effect/EQ/etc., but they're still there.
    Just my $.02
  14. BritTwang
    BritTwang Tele-Holic
    England
    In my quest to buy my '64 I played dozens of the things, Ash, Alder, very light, pretty average weights (none that I would call heavy at 8lbs+). My own is alder and it weighs 7lbs 6oz. All I can tell you is that every single one of them played beautifully and all of them sounded amazing. I didn't get to A/B them to listen out for tiny nuances, but ultimately, whichever one you get, I think you'll be very pleased. I wouldn't worry too much about the smallest of details. These are very very good guitars.
  15. soulman969
    Englewood, CO
    Oh absolutely. Studies have found that for that specific model 7.47982356 lbs is ideal. What kind of scales do you own? ;)
  16. waparker4
    Philadelphia, PA
    Actually when you multiply Euler's number (e) by Pi you get the scientifically proven ideal weight for a Tele-- 8.53973422246 lbs.
    But it only works when you tune the tele to A=432 Hz tuning. :cool:
  17. boris bubbanov
    Hallelujah!
    If a guy is a "sustain freak" then he needs to buy a Les Paul.
    Not a Telecaster. :D
  18. MilwMark
    near Arnold's
    I have 4 Teles (don't ask). All have a Duncan Antiquity in the bridge. All sustain slightly differently. The one that sustains the most effortlessly is also the lightest. I think it's under 6lbs! And Boris nailed it - it's Palwownia. In fact, it's so light it's just on the right side of being a headstock dropper. My "heaviest" (under 7.5 lbs) is right in the middle of the pack for sustain. It's swamp ash I think. Sounds great. Plays great. Each has their own thing going on.
    I think even the composition of a particular piece of wood (not just they type of wood or weight) can have an impact, along with p/u's and amp. Weight is generally a poor indicator of sustain in my experience. YMMV.
  19. Tony Done
    Tony Done Friend of Leo's
    Toowoomba, Australia
    Yes. If I was building a bitsa, it would have a Warmoth chambered alder or swamp ash body. If I was going cheap it would be Paulownia.
  20. Chris S.
    Chris S. Asst. Admin
    Near TELE-Town (Wash. DC)
    IME "weight" has to do with how heavy it is.
    "Tone" refers to how it sounds.
    Apples <=========> Oranges
    You can't measure (or predict) one by the other. CS
