Weber vs. Hoffman ReVibe?
Discussion in 'Shock Brother's DIY Amps' started by alathIN, Aug 18, 2019.
  1. alathIN
    alathIN Tele-Holic
    Indiana
    Would like to hear folks' experiences with both.
    Tempted to go Weber, because the kit is all put together and Weber's is about 20 minutes North of my house.
    Hoffman would have more hunting and scratching, and possibly wind up using a Weber chassis anyway - but maybe higher quality parts? From what I hear Weber has upgraded their formerly-criticized parts act lately...
    tubeswell and Paul-T like this.
  2. corliss1
    Lansing, MI
    I would think just the shipping cost would be worth it to Weber. I personally have never used a kit for anything, but I've only heard good things about both.
  3. Paul-T
    Paul-T Tele-Meister
    London
    Have you seen this thread?. A great Weber build. Also check out
    Sluckey's build, which I think is based on Hoffman.
    Good luck, I want to see one of these. I'm working on the kindergarten version, vis Surfy.
  4. alathIN
    alathIN Tele-Holic
    Indiana
    Yes.
    Sluckey and Moosie are my heroes. I want to be them when I grow up ;-)
  5. DavidP
    DavidP Friend of Leo's
    Vancouver BC, Canada
    I have an early version Weber Revibe that I built years ago, but its sitting on the shelf due to hum issues -- its on my to-do list to rebuild/rewire according to Jeff Gehrings layout, use metal film resistors, Cliff jacks, among other things. However, I neglected to save/bookmarkJeff's excellent descriptions of his mods, so hopefully all that is still accessible somewhere. It would be great to get a thread going here on builds and mods!!
    Paul-T likes this.
  6. milocj
    milocj Friend of Leo's
    Michigan
    I had to go back and find some of his pages during the tail end of my build. I may still have some of his stuff that was downloadable on a USB stick. I'll try to remember to look through them at work tomorrow. Pretty sure he spelled his name Geoff so that may help I'm your search of internet archives
  7. drf64
    drf64 Poster Extraordinaire
    Ada, MI
    No, Jeff is correct. He now posts under "nicht_warhr" on the Weber site. I chatted with him in June.
  8. alathIN
    alathIN Tele-Holic
    Indiana
    This one?
    http://web.archive.org/web/20140410144814/http://home.everestkc.net/jgehring/revibe1-4.html
    Moosie used a ground lift similar to Gehrings' - the circuit itself isn't very complicated, just a couple of diodes and a resistor (or capacitor as others have done it). The fussy part is that you have to isolate ALL the grounds in the unit, including insulating the pots and jacks from the chassis using shoulder washers. Then you connect all those grounds onto a single bus, still isolated from the chassis - so that the only path to ground for anything in the whole unit is through the ground lift circuit.
    Merlin has this at 15.10 in this document: http://www.valvewizard.co.uk/Grounding.pdf
    It's a little different than Jeff's and Moosie's but I think it's all the same basic idea.
    drf64 likes this.
  9. tubeswell
    tubeswell Friend of Leo's
    NZ
    Either way, be careful with ground layout.
    Here's a proven ground system that I use for 6G15s. If you take this same 'galactic ground' logic and apply it to the revibe, you will have minimal ground loop hum.
    separateness and alathIN like this.
  10. alathIN
    alathIN Tele-Holic
    Indiana
    I had something like that in mind.
    What kind of capacitor are you putting in that ground lift circuit?
  11. tubeswell
    NZ
    Just a film cap
    alathIN likes this.
