Dortoh5968
I just completed a Weber 5E3 build in a Hammond aluminum enclosure to fit a custom combo cabinet I built. Everything went well and all the voltage tests are reasonably close to the voltages listed on Rob Robinettes layout. I used Ruby 6v6EH power tubes, a JJ 5Y3 rectifier a Mesa 12ax7 and a JJ 12ay7. My issue is I basically get no distortion at any volume you can stand being in the room with. I tried changing V1 to a 12ax7 and that made a little difference, but not much.
I tested all the voltages and used the output transformer method and came up with a plate dissipation of 10.1 of one tube and 10.39 for the other. I believe these tubes are rated for 14 though I'm not positive. Should a 5E3 be run at 100% plate dissipation?
