Webcor Reel to Reel conversion thread
Discussion in 'Shock Brother's DIY Amps' started by ArcticWhite, May 17, 2018.
  1. Jake Nelson
    Jake Nelson Tele-Meister
    Alexandria, MN
    The problem is that it doesn’t have a 5v heater tap. Only the 6v.
    ArcticWhite likes this.
  2. ArcticWhite
    ArcticWhite Tele-Afflicted
    Portland Oregon
    Hah!
    I'm slow, but at least I'm dumb enough to ask the right question.
    I think I may do RobRob's switchable solid state rectifier.
    Are these the correct diodes to order for this project?
    Jake Nelson likes this.
  3. Jake Nelson
    Alexandria, MN
    Yep. 1N4007
  4. ArcticWhite
    Portland Oregon
    In taking a look at the schematic of the GA-20T, I'm struck by the line of 0047uf caps in channel 2.
    Are these part of the tremolo oscillator?
  5. Jake Nelson
    Alexandria, MN
    The oscillator is the 3 down below. The line of them is a low pass filter that only lets the the oscillations threw and not other unwanted noise.
  6. ArcticWhite
    Portland Oregon
    Anyone got a gut shot of a GA-20T with the board flipped over?
    I don't see those five 0047uf caps in series. Are they under the turret board? Doesn't seem like much room. What type of caps should I use here?
  7. Nickfl
    Nickfl Friend of Leo's
    You should use a high voltage cap for the first in the string, the others can be whatever just.need to be able to take the signal voltage.
    In an amp from that era I'd kind of expect to see ceramic caps used there, but I don't know what Gibson used. I'd be surprised if they are under the board, but maybe.
  8. ArcticWhite
    Portland Oregon
    As they are in the signal path, should I use polyester, polypropylene or something other than ceramics?
  9. Jake Nelson
    Alexandria, MN
    Lots more info on the GA-40 and that board is double sided so it could be. Going to be an interesting build.
  10. Jake Nelson
    Alexandria, MN
    303v with one 6v6 and one 12ax7 with solid state recto
    symbiotic likes this.
