When learning or practicing scales I always used my pinky. Over time it just learned where to go so there's no thought involved.
That’s hilarious. And couldn’t be more wrong in my case.
You’re certainly entitled to your mindset. And I won’t question what worked for you. But it’s exactly the backwards one I was talking about. In my view and experience anyway.
Rock & roll (broadly writ) has largely been created by young idiots, often under the influence of copious substances, who could barely play. But had things to say and sounds to make. Glorious.
as I practice, am focusing on what I think is the right way (trying to incorporate my pinky...
but, for what I want, and be happy with, is a loosening of this 'standards. just want to play and do good stuff. upper 50y.o. guy....with a spark amp, no pressure to perform and be judged on stage.
not saying I'll never use pinky...just perhaps need to refocus practice method maybe.
thoughts?
I'm not sure what point you're trying to make here. Rock and roll and blues were largely developed by very limited musicians and technicians, and if you're content to do nothing but imitate their work you can get by with conceding to their limitations. If you want to make your own music, or you simply object to making needless concessions, why accept totally unnecessary limitations on what you can use? The guitar is difficult enough without hamstringing yourself. Eventually, someone will come up with a second slow blues solo; just think, it could be you.
Developing your pinky is good. Forget the "shred" in the title, not what this is about. These exercises help me. Also Tomo was apparently Mayer's instructor at Berklee.
This is a great point. I should say I view those Tomo exercises (and the Spider, etc.) as warmups (that obviously build technique) before I run through repertoire/play along to records, arps, do some Mickey Baker chord progs etc. I think it’s possible if not necessary to sort of climb both hills at the same time, developing technique along with musical ability/depth. I've also found that learning a new technique can sometimes spin me off in a new direction interest-wise, a la that 'banjo-roll' course on TrueFire, which had me going through a lot of records I wouldn't have otherwise.Start with the sounds and rhythms you want to make.
THEN what technique gets you there.
I honestly think a reason many practice a ton but don’t progress is because the guitar instruction mindset starts with technique in a vacuum and as the goal.
Technique is not the end. It’s a mean to achieve sound and rhythm.
For pinky finger use check out Robben Ford.
You seem very invested in a view that I don’t understand. I’m not sure I understand the assumptions about me either. I have a decent bag of technique and decent (not extensive) practical theory. But that’s a means to an end.
Having the musical idea and wanting to execute it is what motivates the technique. Learning a bunch of techniques in a vacuum is just wanking to me. And an instructional framework built on that model keeps people stuck and frustrated in my view.
YMMV
As a recovering bass player it’s taken years to restrict my tendency to use my pinky. I use three fingers for most playing, but pinky for chordsas I practice, am focusing on what I think is the right way (trying to incorporate my pinky...
thoughts?
Pasquale Grasso needs his pinky to perform this music, it's all aboot your needs.
