Warmoth Necks
Discussion in 'Other T-Types and Partscasters' started by oregomike, May 12, 2019.
  1. oregomike
    oregomike TDPRI Member
    Hood River, OR
    I just read a comment on on e one of the partscaster posts that frets on Warmoth necks still needed leveling. Is this common for their necks? I just plunked down some good $$$ for a custom neck and reading that sort of has me worried.
    Mike
  2. lineboat
    lineboat Friend of Leo's
    I’ve never had to touch one of their necks. They may not be just perfect , but they’ve been fine for me to play without any issues or concerns.
    Skydog1010 and brookdalebill like this.
  3. Nick Fanis
    Nick Fanis Friend of Leo's Ad Free Member
    Athens-GREECE
  4. SecretSquirrel
    SecretSquirrel Friend of Leo's Ad Free Member
    PNW USA
    I received a Warmoth conversion neck a couple weeks ago, and a quick check with a fret rocker showed some slightly high spots, but the frets are really close to level.
    I just got the whole guitar together now (thread coming) and I'm in no hurry to do a fret level, it's playing nicely and I can work on that extra bit of perfection later.
    I think you'll be pleasantly surprised with your neck, even if it can use a light leveling.
    lineboat and nojazzhere like this.
  5. Tonetele
    South Australia
    Glued in frets?? For the price you pay for a Warmouth neck I'd want all wok done and frets properly seated and levelled etc. I'd NOT want glue as you may want to replace them.
    I'll stick to Mighty Mite and do any work myself or have a luthier mate do the crowning and still save money. I also know that Mighty Mite, licensed by Fender ( see SStewmac.com) will fit a neck pocket exactly. Have heard too many not so good stories here and elsewhere about Warmoth, necks in particular.
  6. brookdalebill
    Austin, Tx
    I’ve had about a dozen Warmoth necks over the years.
    None of then needed anything.
    Every one was flawless, both the new, and used ones.
    Great stuff, IMO.
  7. oceanblue
    oceanblue Tele-Meister
    Are they perfect? No. Extremely playable? Absolutely. Probably better than most store bought. Most folks that have built several on the warmoth forum never touch them at all, and think they are great right out of the box, as it were.
    That being said, I took mine to a local tech to check out, and he only found a few high spots, that were completely unnoticeable by me, or him, when playing the guitar. Since it was my own build, I had him PLEK it and for $50 since there wasn't much to do to it. Afterward, I couldn't tell the difference LOL
    DHart likes this.
  8. tele_savales
    tele_savales Tele-Meister
    Brooklyn, Joey!
    Any neck's frets or nut, whether it's on a production guitar (esp at affordable price points), or is an aftermarket replacement, may need to be touched up. In, fact it's probably a skill I should learn myself if I continue to piece together guitars. It's that common.
    That said, I did just send a neck back to Warmoth because the nut slots were sloppy, and I told the rep I wasn't interested in buying a set of nut files. They fixed it, it's totally killer, but I know down the road it will play 100x better with a fret level- I can feel it. Basically, they're not a custom shop. There's no way they can do the kind of close work we'd all like. Their necks would be $1000.
    It is very hard to go wrong with a Warmoth neck. Anyone here will tell you that. There's just also reality to consider.
    Nightclub Dwight and Milspec like this.
  9. Old Deaf Roadie
    Old Deaf Roadie Tele-Holic
    Oregon
    That link simply opened their homepage for me. Is that info still online? I live in the region with Warmoth & USA Custom & use both companies since their products already have a head start on Pacific NW climate.
  10. Lonn
    Lonn Friend of Leo's
    Indiana
    Never had any issues with any of mine. I currently have one of their 59 Roundback conversion necks with the 10-16 compound radius. Love it.
  11. tele_savales
    Brooklyn, Joey!
    "Warmoth's fret installation technique is a hybrid of the compression and glued-fret methods. We first fill the fret slots with a gel-type cyanoacrylate glue. Then the frets are pressed in to the slots. This causes the glue to flow into the voids behind the barbs on the fret tangs. The result is a very stable and durable fret job."
    "Please note, Warmoth does not perform fret leveling. Most Warmoth necks are playable as they are received and do not require fret leveling. However, because wood moves with changes in temperature, humidity and string tension fret leveling may be required. This is best done after the neck has been strung up to pitch for several days and allowed to adjust in the assembled state. For this reason, Warmoth leaves this fine tuning to the end user."
    Old Deaf Roadie likes this.
  12. nojazzhere
    Foat Wuth, Texas
    When I got my Warmoth fatback conversion neck two and a half years ago, the only thing I had to do was touch up the fret ENDS.....just a little. Level was good, and the ends were certainly playable, I was just shooting for perfection.
    lineboat likes this.
  13. JeffBlue
    JeffBlue Tele-Afflicted
    Southern California
    I have many Warmoth necks and each of them are top quality. Never needed fret leveling. My preference is the roasted Maple with stainless steel frets.
    Ian T, Scottz and oceanblue like this.
  14. jazzman1021
    jazzman1021 TDPRI Member
    Earlville IL
    20190509_085644.jpg Applied View attachment 607765 Just got done with this. I'm very pleased with the quality. Only change I made was replacing black plastic truss rod cover with one I made fron Orange Osage. It plays great.
    Kind regards.
  15. alnicopu
    alnicopu Friend of Leo's
    The city
    Yes. My strat neck needed serious leveling. Frets were all over the place.
  16. tfarny
    tfarny Friend of Leo's
    Hudson Valley, NY
    I've had at least a dozen of them. In my experience they are generally great out of the box but any neck might benefit from a little touchup. I have taken a couple of them in for level and dressing and while they were great before the work, they were just about perfect afterwards.
    Also: Without question you want to get the nut worked on, or learn to do it yourself. Most critical and underappreciated part of partscaster assembly is getting the nut just right.
  17. Milspec
    Milspec Friend of Leo's
    Nebraska
    I have yet to meet any instrument necks that were set-up perfectly from the factory. Everything needs a final touch up to meet your specs...especially the nut. I have 4 Warmoth necks and they were all high quality right out of the box which most would have been very happy with just bolting it on and playing. I don't recall any of them "needing" work, I just chose to make some improvements which were always minor.
  18. Skydog1010
    Skydog1010 Tele-Holic Ad Free Member
    North Carolina
    I've never had a mighty mite fit as snug as a fender. Necks require work, even some of the fender brand necks. Think of them as individuals, not something that can be lumped together by brand. Be it Fender. Warmoth, MM.
  19. telemnemonics
    Warmoth necks seem pretty good when new, but a level and crown would add a good bit of $$ to the price.
    A level and crown will make a good neck a little better, but a well made and fretted neck shouldn't be really bad without a level and crown.
    You can't really just level the frets, though some new guitars do have flat fret tops and seem to have been leveled at the factory but not crowned, which is much more time consuming than the leveling.
  20. telemnemonics
    Don't confuse a custom order with changed specs as going through a custom shop or getting custom treatment.
    Those custom orders really boost the price from the very reasonably $150 an in stock neck runs at Warmoth.
    Paying extra for your own specs or specialty woods does not make the neck better, just more expensive and possibly more pretty to look at.
    Still need to budget time or money for basic setup and nut fitting/ tuner mounting etc, depending on what setup options you chose.
    Seems many buy parts assuming after assembly they will have a well setup guitar!
    Then we see "only used for half an hour" necks for sale, because the buyer was somehow unhappy with their perfectly good neck.
    Often we buy these used necks and find holes drilled the wrong size or in the wrong places, stripped or over tightened truss rods etc.
    This is DIY at it's finest!
